Question about FoodSaver Vacuum Food Sealer - V3840
Whats wrong with my food saver
Bag was stuck and now it wont release it or open at all.
2005 quattro , battery is dead and hood wont release.Is it an elecrtonic release?
Heidi, No electric release. The latch is probably stuck. While you pull the interior hood release have an assistant push down and pull up repeatably/vigorously until hood releases from stuck position. Lube latch and cable before closing hood. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Open Hood How To 2001 2005 Audi Allroad Quattro 2002 Audi Allroad Quattro...
2007 Audi A4 2 0t hood latch fix when you can pop the hood
Hood Latch Release Cable Broken How to open hood
Help Hood release cable disconnected somewhere any ideas how to open hood...
Apr 15, 2016 | 2005 Audi Allroad Quattro
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
Can't open vacuum bag compartment
The release button may be stuck or jammed, try pushing in on it and at the same time tapping the area around the button with a heavy wooden spoon, it may be enough to free it.
Nov 10, 2014 | Electrolux Aerus Lux Guardian 9000...
APS film chamber stuck shut. Door won't open when film chamber release button is pressed
Sorry to hear about this issue. If you have a change bag, I would put a few jewelers screwdrivers in it then put the camera in it. With the bag closed up I would attempt to forcibly open the back. With the camera in the bag there is not any chance to expose the film. After the film is removed wind it back into the cartridge. Now send it off for developing.
Good luck,
Cordially,
May 03, 2014 | Minolta Vectis S-1 35mm SLR Camera
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
PASSENGER REAR DOOR WILL NOT SHUT STUCK OPEN?
hello,seems your door brake is stuck-up,remove your door siding,then put some grease or replace your door brake,ty
Apr 26, 2009 | Mercedes-Benz E-Class Cars & Trucks
Honda Goldwing rear side compartment stuck closed.
The 2001 model had a problem with the left compartment. In your main trunk you will find on the left and right side a black button insert, pop it out and with your finger you can push the mechanism down, this will open the compartment. I had to tear into the locking mechanism and shortened a new rod to cure my problem, hope you don't have to go to this extent to cure your problem
Apr 26, 2009 | 2005 Honda GL 1800 Gold Wing ABS
I am unable to open the canister to remove the old bag, unclipping the 2 clips on the side does not release the canister. What am I doing wrong?
Overtime the dirt canister can get somewhat stuck. Once you unclip it, you will need to apply some force and pull down. The dirt canister should release.
Apr 18, 2009 | Broan-NuTone CV350 Central Vacuum
Lens stuck halfway open
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Apr 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
FoodSaver Vacuum Food Sealer - V3840 Logo
101 people viewed this question
Top FoodSaver Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
lucboisseau5
Level 1 Expert
ray gallant
ray gallant
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
