We have two of these generators and neither will start in cold weather
If you want it to start with a start motor, driven from a battery, my guess is the battery is in bad condition. Normally a battery will perform less when temperature is going down, but an old or worn out battery can't perform at all when it is cold. I would check that first. Just take a good battery to start one of them and see what happens. Then see if you want to replace them.
Testimonial: "My generator isn't equipped with a battery."
SOURCE: Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Bad rings or cracked head
