Bosch 1974 Volkswagen Super Beetle Voltage Regulator 74 Volkswagen Su Logo
D
Dave Bird Posted on Nov 22, 2014
My 1974 beetle oil light comes on when the engine is idling on an incline
Edward Quillen
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 11, 2015
Edward Quillen
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1117
Points
First you need to determine whether it is a real low pressure or the sensor is lying to you idling just a slower speed oil pump is running so you can either replace oil pressure switch sensor and see if the problem goes away or you have to put in a pressure gauge to see the exact pressure the sensor is getting it could be a real or it could be the sensor is failing
I am working on a 1974 1641 v.w. engine,i replaced oil strainer gasketsand now cant get nuts srarted back on cover.are there gaskets with different thickness ?
The studs holding the oil strainer and cover may have screwed into the engine block further than required. Back them out of the engine block to increase their lengths.
How do i unlock a vw engine
Dependens upon what is lockeds.
It is is locked due to setting do the following.
Remove spark plugs fill cylinders with light weight oil and let set for several days.Turn crank with a long lever. to turn engine over until loose.
1600 cc beetle
First remove the distributor cap and detach the green wire to the coil. There is a 13 mm nut that holds the clamp to the engine case behind the distributor. Remove it and pull the entire distributor out of the case. Do not drop dirt in... Change the "O" ring and reassemble in the reverse order. The "O'' ring is a VW part and not any "O" ring will work.
Wiring diagrams fig
WHAT PART OF WIRING DO YOU NEED DONE??YOU CAN CHECK THIS COMPANY CALLED JC WHITNEY FOR COMPLETE WIRE HARNESS FOR UR 74 COMES COMPLETE FROM FRONT HEAD LIGHTS ALL THE WAYTO REAR LIGHTS,ENGINE EVERYTHING..
1helpful
I need a wiring diagram for a 1974 vw beetle
samba bus .com wiring diagrams they are free
Blue thermostat light comes on after driving for 5 miles or so and stays on; after driving for 20 miles or so on occasion the oil pressure light comes on when car slows down and is idling.
when the thermostat in a beetle goes, it stays in the open position, so it could be you blue light is indicating a "cold system",change the thermostat.
the oil light will come on if low on oil or you have a low pressure,try using 10/40 semi synthetic oil.and mloyslip.if no improvement you will need to renew the oil pump.
Oil pressure light comes on when I put the car in motion (at about 2000 rpms)
all turbo engines have a oil line to the turbo. If it is not getting oil the turbo will burn up and have to be replaced. Change your oil and filter to start with.
Top Bosch Electronics - Others Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Electronics - Other Expert? Answer questions, earn points and help others
