Cinavia has been widely used in new Blu-ray movies and Blu-ray players. If you want to play the Cinavia protected disc, you can seek help from Leawo Blu-ray Cinavia Removal program which can help you easily remove the Cinavia protection on your discs.
The different codes are telling you, there is a copyright protection on the sound or the video. Sometimes parts are protected, because it was intended for other use.
See the link to:
Cinavia Messages Message Code 1
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
SOURCE: My lg blue ray dvd player wont play regular dvd's
sounds like a bad optic or a software issue
SOURCE: BD-HP21U problems playing discs
You have inadvertently downloaded the US (or other region) version of the firmware. Unfortunately if you try and download the UK version the HP21 just tells you you have already installed it. I was told mine the only way to reset it is for it to be sent to Sharp or you can wait for a new firmware update.
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
SOURCE: I can't get my blue ray player to play Avatar Blue
Like Kelt67 said a firmware is needed....Avatar holds a lot of memory on the blu ray disc as that's one reason there are no trailers just strictly the movie and that's it on the blu ray....Avatar works perfectly fine in my PS3 but then my fiance tried watching on a regular Sony blu ray player and it just sits and loads forever....needs a firmware upgrade need to pop the firmware disc in and download by contacting your blu ray manufacture if no ethernet port on your blu ray player.
compatibility with this model 525p and 625p
DVD player..."
Um, no Blu-Ray.
