Try a reset to this set, and check. If it do not help you, the main board to it is faulty. Contact the authorized service centre.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Sceptre X32GV-Komodo
See troubleshooting (p.96-99) of user manual
but Unfortunately i think this problem is for Sceptre ...
For technical help, contact our Sceptre Technical Support Group via email or
phone. Please have your Sceptre p/n number, serial number, and date of
purchase available before you call.
Tech Support E-mail : [email protected]
Customer Service Email : [email protected]
TEL : 1800-788-2878
Operation Hours : Mon - Fri at 8:30 AM – 5:30 PM Pacific Standard Time
SOURCE: at power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
