UPG 12V 35AH Jazzy Select GT Power Chair Scooter Battery - 2 Pack - UB12350MP2494 Logo
g
gloria Allen Posted on Nov 21, 2014
I jhave a Jazzy Select GT power chair, I put the charger on it when the light shown red and green, when it powers up when charged the both lights will turn green, but now it will do nothing with start
I put the charger on and both lights are green on the charger but nothing will come up on the joy stick where you turn it on.
Gino Borg
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 87 Answers
  • Posted on Nov 25, 2014
Gino Borg
Contributor
Level 1:
New Friend:
Cheetah:
Answers
87
Questions
Helped
31571
Points
97
Hi Gloria,
The first thing you need to do is measure the voltage at the charging socket of the Joystick (outside 2 pins). This will determine a lot of things, so I can guide you further.
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Power light is on the charger but no movement from the jazzy select chair
You have to disconnect the charger in order for the chair to move. It automatically removes power from the controller while the batteries charge.
Jazzy charge light on chager does not come on
The red light indicates that power to the off-board charger is on. Try a different ac wall outlet that you know works. If a red or green light does not come on you will need to replace charger. Also check the condition of your batteries - dead batteries will not charge.
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Replaced batteries in Jazzy 600 but they will not charge up.
doug then you could have received a bad battery or you have a charger problem or a charger circuit problem. If the chair comes on then the wiring is ok. when you plug the charger in do you have a green light and a yellow light on the charger? (when fully charged the light goes from yellow to green indicating full charge) If when you plug the charger in and you have a red and green light then there is a problem with the charging citcuit. I would contact your provider where you got the chair to have them check it out for you Hope this helps
2helpful
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Top UPG Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an UPG Health and Beauty Expert? Answer questions, earn points and help others
