window 7 right click on the speaker icon in the taskbar select either playback or recording devices you should see your microphone listed under the recording tab right click on it select
properties at the bottom select use this device enable
hope this helps
Please click this Check Your Audio and Video Devices to test your audio/video.
Do you have the correct audio devices selected? Did the test work?
After doing the above. Click this link to call the Skype test call echo 123:Click Here You should hear the voice and your recorded voice as well, if everything is ok.
Addtionally, are you on the most current release? If not install over what you have by clicking the "Windows 5.8" link below as well. You can do the above tests again after upgrading as well if needed.
Oh,Thank you very much for spending Time on reading my problem, you were so helpful.-Ashely
