I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning. [ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory. Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Codes to check with ILO TV are: 0198 1070 1024 1023 . Keep in mind that. If one code do not match with your TV, try an other code only after switch OFF the TV by its Main Power On/Off switch, and switch it back again. Direct Code Entry
Press and hold the SETUP button until the red indicator stays on, then
release the SETUP button.
Press and release the desired Mode button (TV, VCR, etc.). The red indicator
blinks, then stays lit.
Enter the 4 digit code from the code tables. Note: after a valid code entry,
the red indicator turns off. For an invalid code, the red indicator flashes.
With your device on, press CHANNEL UP. If the device responds, no further
programming is required. Note: If some buttons do not operate your device, try
one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your
brand is not listed, try doing a search of the code library for your code by
following these steps.
Manually turn on the device (TV, VCR, etc.) to be controlled.
blinks once, then stays on.
Press the CHANNEL UP button repeatedly (up to 300 times) until the device to
be controlled changes channel. The red indicator blinks, then stays lit.
Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes
under CBL, etc. If you want to store a VCR code under CBL, etc., first follow
the procedure for Direct Code Entry and press CBL in step 2 of Direct Code
Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the
steps above for Code Search.
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. I have only tried this with an LG TV. Hopefully it helps you out. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working. Maybe you'd need to press something else instead of TV for a VCR? But the trick is to be about 1mm away from the signal receiver. I literally put it in front of the red light of the tv.
I found the manual online for the URC-7710, but i do not see a code for an Acer TV.
Try a code search by following these steps:
1. Turn on TV. 2. Hold down the Magic button, the red light will blink once then twice, release the Magic button. 3. Press 991, the red light will blink twice. 4. Press power button once. 5. Aim remote at TV and press the Channel Up button repeatedly (up to 150 times) until TV turns off. Note: if you skipped the code that turned the TV off you can go back by pressing the Channel Down button once. 6. Press the Magic button to store the code for your TV set.
1. press and hold setup button until the red light stays on. 2. press and release the desired mode button (example t. v.) the light will blink and then stay on. 3. enter one of the 4digit codes. note: if the code is valid the light will turn off if it flashes it is an invalid code. 4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
CODES:1171,0116,0167,0176,0922
1.manually turn on the t.v. 2.press and hold the setup button. 3. press and release the tv button the light will blink once and then stay on. 4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit. 5. press and release the mute button to store the code the light will go off.
1. Turn TV on
2. Press TV key on remote.
3, Press and Hold magic button until red light blinks twice, it will blink once and then twice.
4. enter 991 red light will blink twice
5. Hit the power button
6. Aim the remote at the TV and press the channel plus button until the TV turns off.
7. Hit the magic button as soon as the TV turns off to store the code.
I do not believe this is available on-line, but have some info that might help you use the remote.
To Search For A Code:
Manually turn on device to be controlled.
Press and hold the "Code Search" button until the red indicator light stays on, then release it.
Press and quickly release the desired ode button (TV, VCR, etc.). The red indicator light should blink once.
Press the "Channel Up" button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator light should blink off with each button press. If you accidentally overshoot the required code, press the "Channel Down" button to backtrack through the library until the device changes channel. Pressing "Channel Up" changes direction again.
Press and release "Mute" button to install the code.
To Identify The Code That Was Found:
Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
Press and release the "Code Search" button. The red indicator light goes off.
To find the first digit for the code stored under the mode key pressed in "Step 2" press each numeric key from 1-9 in turn. When the red indicator light blinks off, the number you pressed is the first digit for the code you are searching for.
To find the second digit, repeat "Step 4," this time when the red indicator light blinks off, this is the second digit in your number.
Repeat again for the third digit in your code number.
TO PROGRAM THE remote USING THE 3 DIGIT CODE: 1. Turn on the TV receiver 2. Press TV on the Sky Remote Control 3.
Hold down SELECT and the RED buttons together for approximately two
seconds, until the RED LED on the Sky remote blinks twice. 4. Enter three digit code from list for the receiver (early versions now flash twice). 5. Press select to enter code structure (the LED will flash twice if a valid code has been entered). 6. Now press the STDBY button and test other functions. Repeat if necessary until a code is found that works most common functions. TO PROGRAM THE remote USING THE 4 DIGIT CODE: 1. Turn your TV on. 2. Press tv on your Sky remote control. 3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice. 4. Press tv on your Sky remote control again. 5.
Key in the four digit code for your brand of TV. The light on the Sky
remote control blinks twice. If the light blinks once only, recheck the
code for your brand of TV and start again at Step 1. 6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code). If
at this point the LED on the Sky remote control blinks three times then
all possible codes for that make of receiver have been checked. Repeat
from step one, ensuring that you enter the correct manufacturer code. At
the end of the sequence, if you see the TV Guide screen, the remote
control setup process is complete. If you did not see the TV Guide
screen, you must now complete the following steps. 8. Press tv on your Sky remote control. 9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. 10. Key in the number of the channel on your TV that you use for watching satellite TV. 11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete. If
after trying this, you still have problems, call your broadcaster's
help desk. For your broadcaster's help desk number, select the
Telephone Numbers option from the Services screen.
seconds, until the red light on the Skyremote control blinks twice.
4. Press tv on your Skyremote control again.
5. Key in the four digit code for your brand of TV. The light on the Skyremote
control blinks twice. If the light blinks once only, recheck the code for your
6. Press the standby button on your Skyremote control. If your TV
switches off, press select. The light on the Skyremote control blinks
If at this point the LED on the Skyremote control blinks three times then all
possible codes for that make of receiver have been checked. Repeat from step
At the end of the sequence, if you see the TV Guide screen, the remote control
setup process is complete. If you did not see the TV Guide screen, you must now
8. Press tv on your Skyremote control.
satellite TV.
11. Press select on your Skyremote control. The red light blinks twice. The
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice. If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide . If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
