Http://www.ask-tsc.com/pdf/KX-T76xx.pdf
Download the user manual to this phone by this link. It has all details.
Electro help
SOURCE: need to set the time
From the phone plugged into jack 1, usually 101, press PROG **1234 000 enter. Your date and time is changed using the arrow and NEXT keys and ENTER sets it after you're done.
Carl
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
SOURCE: change ringer on panasonic kx-t7633
1) Press PROG button.
2) Press CO or INTERCOM button twice. Choose between 1-30 type of ring tones.
3) Press ENTER or STORE button.
4) Press EXIT or PROG.
Hey refer to the manual for more details:
http://www.fixya.com/support/p123989-panasonic_kx_t7633_corded_phone/manual-7455/page-13
YBC (/\)
SOURCE: Headset set up on a KX-T7633
First make sure that your headset is really compatible with the Panasonic
phone. After plug in the headset to phone then u need to enable the
headset mode. To do this:
1) Press PROG.
2) Press program no. 61 (headset mode) and then press ENTER or STORE.
3) Press selection no. 0=OFF, 1=ON headset mode and then press ENTER or STORE again.
YBC (/\)
SOURCE: changing time on PAnasonic KX-T7633?
This is what worked for me :
program, **, passw 1234, you change the time/date, and then to store, press Autodial or store button.
Hope this helps!
Caroll
