<!-- from fixya rte -->How to change silent mode from on to off? - Uniden DECT1560 DECT 6.0 Single-Line Digital Cordless Telephone w/ 1 Cordless Handsets, Caller ID & Call Waiting, Speakerphone, LCD display, Intercom function, Wireless Network Friendly, Eco-Mode for Power Saving, Eco-Friendly, Expandable up to 6 Handsets
Press the Android phone's "Power" button and hold it until a menu appears on the screen. Clear the "Silent Mode" check box in the menu to disable the Silent Mode option. Press the "Up" volume button on the Android phone until the Silent Mode icon on the screen changes. https://smallbusiness.chron.com/disabling-silent-mode-android-33186.html
"Silent Mode" is entered by pressing and holding the [ # ] key
on the handset for a few seconds (model D1680 & similar).
The easy way to end "Silent Mode" is to go to the BASE and
press the [ANS ON/OFF] button to turn off the answering
machine system. (push the button, do not unplug the power)
"Silent Mode" will clear a moment later and you can again
turn on the answering machine system as desired.
I got.....
Silent Mode
You can silence the ringers on the base and all handsets for a specific
period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold #
on any handset. The phone prompts you to select the number of hours ( 1 - 9 or Always On ) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.
After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering
system, the phone exits silent mode.
1. With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
2. To confirm, press # or just wait about 5 seconds. The phone displays Silent Mode On on each handset.
3. After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
Press and hold the pound key (#) until it exits silent mode.
Here is the original text from the manual of the phone:
"Quickly Switching to Silent Mode Silent mode is convenient when you wish to stop the phone from making noise, in a theater for example. In Idle mode, press and hold the "#" key until the “Silent Mode” message and the Vibration icon display...
To exit and reactivate the previous sound settings, press and hold the # key again until “Exit Silent Mode” appears. The Vibration icon no longer displays."
You can also download the pdf file for the phone's manual online by simply googling "Samsung x427m pdf manual."
you want to enable silent mode, just hold down # You can switch quickly between General and Silent this way. While in silent , you can change it to vibrate also.
or by holding down the # key :) you may have changed the profile itself, so check under profiles > Silent check the settings in there are actually set to silent...
hi, have you tried enter setup then profile then select general this should then set your phone back to normal if not then instead of going to general go to silent and change the settings under the silent profile, like turn ringtone on and select ringtone. Try the first option first as this is quick and easy failing than then just change the settings under the silent profile then you can even change the name from silent to general then you can change one of the other profiles to silent so try it then get back to me if you need further assistance ok
