Question about Electrical Supplies
Why does my Ryobi 2200 watt generator surge at low RPM's
Surges at all RPM's, but primarily when not under a load.
    New Friend:
  • 58 Answers
Engine governor sensitivity may be set too high, it keeps correcting too much, it's typical for all generators, 1 KW - 1 mega watts units.
Posted on Nov 26, 2014
2 Suggested Answers
SOURCE:
  • 11 Answers
SOURCE: Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Posted on Sep 10, 2008
Check for a weak or missing spring on the throttle linkeage.
Nov 17, 2014 | Electrical Supplies
That sounds like dirty/clogged idle circuit passages in the carbureator. A little spary carb cleaner might work, but you might have to rebuild it.
Vacuum diagram for 98 dodge ram 1500 5.9 liter
The vacuum diagram is under the hood on the federal emission system sticker. We do not have it.
Oct 26, 2012 | 1998 Dodge Ram 1500 4WD
Have a Honda EU6500is generator with 410 hours. I live off grid and run the gen 2-3 hours daily. The generator rpm surges under load on eco throttle and surges under load AND without load when the eco is...
i have the same problem with a new one ,take a peace of paper and cover the battery cover air inlet when it's running ,if your problem stops-it's the seal around the cover,a honda rep let the cat out of the bag,---jk
Sep 08, 2011 | Honda Electrical Supplies
I have a 2006 Chevy Silverado 1500 4X4 ext. cab/short bed. The 5.3l engine surges and sometimes falters (+- 150 rpm) between 30-58 mph in high gear under a slight load. There is no surging or faltering...
is it a automatic because it sounds like the lockup converter try changing the fluid and add a friction modifier napa sells different ones per manufacture
Nov 03, 2010 | 2006 Chevrolet Silverado
2009 YARIS RPM SURGE
best to take it back to main dealer, if they cant sort it get them to replace the car as it only 1year old dont take any **** from the main dealer
Jun 05, 2009 | 2008 Toyota Yaris Sedan
Engine surges under load at 3800 rpm
yes it could be. have fuel pump pressure tested, fuel pump pressure should be. (key on engine off) 1999 to 2000--with egr--41 to 47 psi without egr--52 to 58 psi,
May 30, 2009 | 1999 Pontiac Grand Am GT
Electrical Supplies Logo
978 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
