Sony DPP-FP95  Digital Photo Printer Logo
J
John Mwanri Posted on Nov 16, 2014
When I pressed the blue lever but ink ribbon fail to eject
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
What would cause the ribbon guide to not lift to ball strike position?
Check ribbon adjustment there is an adjustment lever that adjusts the ribbon up and down.Also check that the ribbon is still good not wore out,out of ink.
How do you remove the ink cartridge from a Royal Alpha 2001.
If memory is working there is a lever with a red end just to the R. of the ribbon, pull it toward you untill it stops the ribbon cassette should lift out.
DickyO
How do you load a new ink cartridge?
Replacing the Print Cartridge
1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover.
2 Remove the old print cartridge containing the used ribbon and dispose of it.
3 Remove the plastic stopper from the new print cartridge.
Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them.
4 Turn the black spool on the right clockwise to tighten the ribbon as shown.
5 Install the new print cartridge by inserting the recessed first, and then placing
the cartridge into its four holders.
6 Press down on both sides of the top cover to close it securely.
7 Close the front cover.
Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Vertical Black Lines When Receiving
The sender's scanner may be dirty. Ask the sender to make a copy to see if the
problem is with the sending machine. Try receiving from another fax machine.
If the problem continues, call Brother Customer Service at 1-800-284-4329
You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF).
Installation instructions will be included. If you handle the print cartridge (frame)
carefully, you can reuse it until it breaks.
How can i relace the dmp printer head with new one
  • 1-Turn off printer,
  • 2-Open the printer's front cover to access the printer's ribbon and printhead.
  • 3-Spray the ribbon and printhead with short sprays of air from a can of compressed air to remove any ink, dust and dirt buildup from the components.
  • 4-Use a flashlight to locate the printhead's adjustment lever. The lever is on the left side of the printhead.
  • 5-Push the lever toward the ribbon. This will place the printhead closer to the ribbon so the print will be darker.
  • 6-Close the printer's front cover. Turn on the printer.
  • 7-Print a test document. If the print is still too light, replace the ribbon.
    If the print is too dark, turn off the printer and move the printhead's adjustment lever slightly away from the ribbon.
  • Please Rate this solution. Regards.
    1helpful
    I own the the Pioneer DEH-P9800BT and my screen will not come on. if i press the eject button the screen will come on when its open, when i press it again to shut it the screen goes blank. I have no idea...
    You will get this problem when the printed ribbon is slightly cut because of the repeated opening and folding of the screen. Eventually, the ribbon will be cut to the point that you won't get any sort of response when pushing any of the buttons on the faceplate. Order this part number and replace it. P/N:XNP7026. You can get one from Ebay that already has the connector plate soldered on, if you do not have any experience with soldering to printed circuits. Connecting it is fairly straight forward. Remove the top plate of the receiver, 4 screws securing the cd-unit, unlatch the ribbon (paying close attention to how the ribbon was routed). Reroute new printed ribbon and reassemble the unit in reverse order. Good luck, hope this helps because I was rather upset when mine failed.
    I need to know the proper insertion of the PS3 power eject button ribbon. Narrow ribbon with writing on one side.
    small flex has blue tabs on each end. Insert flex with blue pull tabs in the up position. Small writing goes down!
    4answers
    Won't boot up, can't eject disk tray
    buy an xbox i mod them and have absolutely no problems
    1helpful
    3answers
    Not getting ink from cartridge to paper, i believe my gap settings are messed up.
    A few possibilities here: One, is your ribbon cartridge dried out (essentially out of ink)? Dot Matrix printers aren't near as common now, and if your cartridge has been in the retailer's stock for years, then it could indeed be dried out. Another, the ribbon isn't being advanced, or spooled. The ribbon is spooled as the head carriage moves back and forth. If it isn't being spooled, the ink in the spot over the printhead will be quickly depleted. A no-spooling condition is usually caused by a problem in the cartridge itself. Also, make sure the cartridge is properly seated in the holder. If it isn't, the drive spindle isn't fitting up into the cartridge properly, and might not actually drive the mechanism inside the cartridge. Lastly, if your cartridge is dry, they can be reinked if you can find someone with the reinker to do it. I once did ribbon reinking with a Macinker as a side business, and someone in your area might have one of those rigs. Otherwise, just buy a new cartridge, and hopefully it will be reasonably fresh, with good ink.
    Top Sony Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    matt martin
    matt martin
    Accurate TV Repair...
    Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
