How do i set the clock on Whirlpool built in double oven? Can't find a model number. 5 buttons from left to right. Alarm bell, clock with hand at 12, clock with hand at 3, + and - signs. Please help! My 81 year old mother has moved into a new home and there are no manuals and i can't work it out!
The model number is usually located on the side of the door or on side of the oven cavity area near the door opening. Sometimes if you have a drawer or warmer the model number is located on the oven side of the drawer or warmer (sometimes not directly facing you but on the side of that area. If the oven is electronic you press a clock button or you hold one of those buttons for a couple of seconds like a start or set button. The model number though will help you find a user manual and it for sure should be clear. I hope this helps you.
Testimonial: "Thanks very much for the advice; eventually found the model number and so the manual. Now just have to hope the clock does work!"
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
SOURCE: After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
SOURCE: whirlpool double oven. fan assisted oven is not heating up fan is
NEEDS A NEW HEATING ELEMENT
SOURCE: element wires fell behind oven
I just had the same problem with our Electrolux wall oven. I don't expect you are still having problems 3 years later, but thought I would post for the benefit of anyone else with this issue.
Firstly, turn your power off. I then had to unscrew two screws on each side of the oven door which allowed the oven shell to come forward. You should then see the power cord which you can remove from the powerpoint. If your oven is hard-wired in, then I would definitely call an electrician.
Once I removed the oven, I placed it on the floor and unscrewed a few screws that held the top and back casing on. After removing the casing, you can see the wiring and you just need to push the fallen wire back through.
Before you put the casing back on, you could replace your element just in case the wire falls through again.
SOURCE: The schematic for my oven
Diagrams begin on page 47
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Thank you for the advice - eventually managed to find the model number and so a manual. Here's hoping the clock does actually work!!
