Question about Hisense Televison & Video
How can I connect my hisense tv to wifi? it wont show my wifi name in security mode. when I scan it says no ap?
We had the same problem went into system settings and reset the wifi. Had re add the wifi and password.
Posted on Jan 02, 2019
    New Friend:
  • 125 Answers
Either your router is not set up to broadcast the SSID(network name),the router is too far away from the TV, or there is a problem with the wireless on the TV.
If you can see the SSID from the same location with your phone/tablet/etc then it is probably an issue with the TV. You can also check for a firmware update for both the TV and the router.
Posted on Dec 03, 2014
SOURCE:
I have a hisense tv 32” how do I connect to wireless wifi
This would depend on the model and whether it was a SMART TV.
The internet connection is via a LAN cable or via your satellite or cable box to your Home Network. Your smartphone connect to wifi and via that to the television.
Feb 05, 2018 | Hisense Televison & Video
Hisense roku tv wont connect to wifi today
Unplug the device and try again after 5 minutes, also reset the router.
Nov 10, 2016 | Hisense Televison & Video
I have an Amazon Kimble and now have a new WuFi service. I don't have or don't rember ehw password so I can't get into the store to download books. Can you help?
Is it WiFi in your home? If that's the case, and, you still can't remember/find your network's username and password--try resetting the wireless router (or access point--AP) to default factory settings. Use your PC or laptop to reenter factory settings with the router's/AP's networking address entered into a browser (likely Internet Explorer)--it should appear as something like 168.192.0.1 (depending upon your particular router)--it's in the manual.
If you don't have a manual, download the PDF version from the router/AP manufacturer online. Navigate within the menus provided on your PC's/laptop's screen. One of the menus should offer default factory reset. Indicate "Yes." (If you can't read a PDF file on your PC/laptop, download and install the free Adobe Reader from adobe.com.)
Once the router is reset, the manual indicates the temporary username and password to use for WiFi. This is the time, though, to invoke security once again for the router/AP--enter a sensible and secure username and password--something memorable, yet difficult for others to determine. Use letters, numbers, and even certain special characters. Follow the instructions to set up security, replacing the simple username and password--use WPA2 or WPA (encryption). WPA2 is the most secure.
Now's the time to configure the Kindle or other tablet: You need to find the WiFI settings menu in your Kindle--after enabling WiFI in the tablet, find your router/AP user name you just configured via your PC/Laptop in the Kindle menu--perhaps among those from other WiFi signals from neighbors or businesses. Choose your username, and enter the password. It should connect--securely now.
In a few locales in America (say, in California), not configuring security even proves illegal. Always secure your wireless network--people actually may scan for networks in order to share bandwidth--or, far worse, to garner sensitive personal info and otherwise hack in. Even these days, many people refuse to take sensible steps towards security--they're happy to get a connection of any type--not being locked out of their WiFI by forgotten security, either. That's a "shortcut to thinking."
Aug 08, 2013 | Amazon Kindle Wireless Reading Device
HOW TO Connect tl-740n wireless WIFI router to PTCL DSL WIFI ROUTER
The easiest way to chain two wireless routers. *Please note this is just to have wireless access*
Make sure DHCP is enabled for both, make sure their SSID (the name that shows up when you connect to it) is different.
Make sure they are both different networks. So for example configure the first for 192.168.0.0 network and the other for 192.168.1.0. Now plug an Ethernet cable from the 740n router (WAN) port into a (LAN)
Second method *This only works if the tl-740 router supports AP mode (Access point).
In the configuration of the 740 router, enable AP mode and make sure DHCP and nat are turned off if they are on. Configure the wireless to operate on channel 1 6 or 11. Name the SSID the same as the other router. Plug in Ethernet from WAN 740 to LAN on the other router. Now on the DSL router make sure the SSID is the same and select a different channel from (1,6,11). Now you're all set.
Jan 26, 2013 | D-Link DSL-G604T Wireless Router
How to connect to secured WiFi connection with i9003?
Go to settings. < wireless and network Press scan for network Your network name will be visible. Click on the network name and select connect. It will ask for key. Enter the key used to secure wifi network.
you are connected to secured wifi network.
May 25, 2011 | Samsung Galaxy S GTI9000 Smartphone
My computer won't recognize my wi-fi printer. I need the Access point name and Network Key. (I think). I don't know how to find it.
For this to work, both your computer and your wi-fi printer must have the same security settings and passwork For trouble-shooting, it is useful to turn all encryption and authentication off. See below for instructions.
This problems would be easier to solve if you gave the model Dell AP. For the 1100, connect to the AP (use wired cable if your PC isn't configured for wifi connection to the AP and follow these steps. For other APs, goto Dell's documentation site and check for your model.
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&cs=19&l=en&s=dhs&~subcat=112&~cat=4
Enter or change the AP's SSID ExpressSetup : Summary Status > Setup> Express Setup Enter or change the AP name ExpressSetup : Summary Status > Setup > Express Setup Setup WEP DataEncryption :Summary Status > Setup > Security>Radio Data Encryption (WEP)
Feb 26, 2011 | Dell Computers & Internet
What options do i have to get intrnet connections two networks show up and shows the ssid but it still wont let me
well sir it seems that you are trying to wifi on your laptop via a secure wifi AP .you need a network key or password to get access
Dec 17, 2010 | Acer Aspire One D255-2670
Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Wlan dosent connect to net work
Make sure that your wlan is on, search your wifi ap broadcast by doble click wlan icon under the top corner desktop, double click search if wifi ap appear you can connect by doble click connect bar, if wifi have security you must write or set the security setting like wifi ap by consult with admin wifi. In order to best conection you must in range of wifi signal not so far from your ap.
Sep 26, 2008 | Sony Computers & Internet
LAN
wifi0] Chipset AR5413 802.11abg NIC (rev 01)
-- If -- Mode -- SSID --------------------------- Hide -- Security -
>> ETH02 AP Trusted Network no WPA-EAP
ETH03 AP Guest Network no Plaintext
[wifi1] Chipset AR5413 802.11abg NIC (rev 01)
COMMANDS
<N> New SSID <M> Modify SSID
<D> Delete SSID <I> Show Information
<C> Std/Channel/Tx-Power
<L> List Stations <S> Channel Scanning
<R> Restarting Devices <Q> Quit
May 24, 2008 | D-Link Computers & Internet
Televison & Video Logo
2,037 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
