Device error
An internal error occurred in the device.
Press (Select) to resume the job.
Door open
The printer door is open.
The door must be closed before printing can continue.
Engine comm. error
The device experienced an internal communication error.
This is a warning message only. Job output might be affected.
Invalid driver
You are using the incorrect printer driver.
Reselect the printer driver appropriate for your device.
Invalid entry
Invalid data or response.
Correct the entry.
Jam in Cartridge area
A paper jam has occurred in the print path.
Open the door and clear the jam. Then press the (Select) button on the control panel
Jam in Output bin
A paper jam has occurred in the output area.
Clear the jam, and then press the (Select) button on the control panel.
Jam in print paper path.
Open the door and clear the jam. Then press the (Select) button on the control panel.
Jam in tray 2
A paper jam has occurred in Tray 2.
Jam in tray 3
A paper jam has occurred in Tray 3.
Load paper
The HP Color LaserJet 1600 printer is out of paper.
Please load specified paper type into the tray indicated.
Load Tray X [TYPE] [SIZE]
The printer is processing job, but the tray indicated is empty.
Please load specified paper type and size into the tray indicated.
Manual feed
The printer is waiting for paper in the tray indicated
Load the paper as indicated.
Memory is low
The device memory has been almost completely filled.
Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages.
Misprint
The printed pages have been incorrectly placed on the paper.
To continue, press the (Select) button on the control panel.
One of the reasons why such error flashes is because the paper or media your are using might not be suitable for the printer. Always check on your paper preference before printing.
@Linzi_mackie
"c48 not loading..."
Check that paper is not curled at leading edge.
Some printers are finicky about exact straightness.
Otherwise check:
Paper not glossy - roller-gripper may be doing a 'wheelie' on the edge.
Rubber gripper not worn down - the pickup roller usually has one or more rubber 'rings' around the roller to grab & feed paper by friction.
If all else fails, open cover and inspect gearing to roller, broken brackets which can cause misalignment.
Try running 'open' and see what happens.
Regards,
Clive.
Hello... i have a copier IR6570. If i load the paper from tray 1, it always jammed. But if i load from other trays, everything goes well. Can anyone help me, please...?.
use an antistatic vaccum or canned compressed air to clean the interior of the printer.this problem may cause by dust and debris inside the printer.inspect for any broken part in the paper path.if u find any u will have to investigate repairing or replacing the printer. try using different weight paper .some printers work best with the particular weight of paper and if you use paper too thick or too thin jams can usually occur.thanks
I need to know if it still reads "paper jam?" If so, there must either be some piece of paper that is triggering the paper sensor, or the paper sensor actuator has become misaligned.
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
