HP PSC 1510 All-In-One InkJet Printer Logo
k
ken Innis Posted on Nov 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
<!-- from fixya rte -->Make font larger on HP1510 printer - HP PSC 1510 All-In-One InkJet Printer
Rick Offinger
Level 2:
Scholar:
New Friend:
  • Expert 46 Answers
  • Posted on Nov 27, 2014
Rick Offinger
Expert
Level 2:
Scholar:
New Friend:
Answers
46
Questions
Helped
29046
Points
182
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
1helpful
2answers
MAKE MY HP OFFICEJET 5610 PRINTER PRINT LARGER
The only way a printer should print larger is that you should WRITE your text with larger fonts.
You should select font size on your word processing application, call it nopepad, wordpad, winword or any other similar application.
If you tell us the application and the version you are using for word processing, might help you select a larger fornt
Ada masalah dgn printer HP1510 tidak bisa print word atau excel tp untuk photo dan PDF bisa.apa kira kira ya
So you cannot print using the print dialog to your HP1510 printer in word or excel but you can print to PDF? Is that correct?
Jadi Anda tidak dapat mencetak menggunakan dialog cetak ke printer HP1510 Anda dalam kata atau excel tetapi Anda dapat mencetak ke PDF? Apakah itu benar?
2answers
I need to make the font size LARGER.
To print a larger font size, you need to change the size of the text in the document.
For example if this document is a WORD document then when the document is opened in WORD you select your text and then click on the Font size and change it to a larger size.
If it is a new word document, you can set the font size before you start typing.
Don't forget to save the changes in your document.
I have two printer and on one the label size comes out with the correct font size but when I try to print out the same label on the second one the bar code and human readable is much larger...am I missing...
Yes. You have two printers that have different "dots per inch" print heads. The printer with the correct size font is a 300dpi printer and the second one is a 203dpi printer. That's why the bar code and text is printing larger with the same code being sent to the first printer. The dots on the printhead are larger therefore, larger print.
Change the printer driver on the second printer to Z105SL-300 dpi and the print will be just fine.
Hope that helps !
I have a 105SL connected directly to a pc using Bar Tender. It takes for ever to print and when it does the printed label is 1/4 larger than what I specified. keep it simple, has I am not an IT expert.....
Ok...two items to check:
1. slow print can be caused by using True-Type fonts like Arial, Times New Roman, etc...these fonts do not reside in the firmware of the printer so Bartender has to download the fonts to the printer's memory hence the long print time. Change any text fonts to Zebra's internal fonts which you should be able see as a choice from Bartender.
2. If the print is larger than you expect, then you are using a printer driver that is not correct for the dpi (dots per inch) of the printer than have. If your printer is a 203dpi printer but you use a 300dpi printer driver, then your print will be larger that you expect. Bartender will format the fields for 300dpi but because size is larger on a 203dpi, the print will be larger. The Z105SL comes in both sizes, 203 or 300. Just verify your printer to the driver being used.
Hope that helps !
Prints in to small of font. How do I get a larger font
The larger fonts you are getting in your application, like Microsoft Word for example, the printer is not to blame for this. Just increase the font size from your application.
Printer looses font settings
>this may be help ful
http://support.microsoft.com/kb/276435
>lets change the default printer and check
1helpful
2answers
Font size problem when printing documents
Font sizes are a program thing nothing to do with the printer
 Examine your E-mail client set up in the read section[Different E-mail programs different setting ] probably under a heading
Tools/Options and look at how the font sizes are organized.
1helpful
3answers
Brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
k24674
Grand Canyon Tech
Grand Canyon Tech
