Expert
- Posted on Jul 06, 2009
Re: Remove and replace passenger door mirror on 2009 ford...
- Remove the front door trim panel handle bezel cover.
- Remove the front door trim panel handle bezel screws.
- Remove the front door trim panel lower screws.
NOTICE: To avoid damaging the front door trim panel, do not pull the bottom of the panel outward.
- Remove the front door trim panel by lifting upward on the armrest to disengage the panel clips.
- Disconnect the electrical connectors.
- Disconnect the lock rod cable from the front door trim panel.
- Disconnect the door handle conduit and cable from the front door trim panel.
- To install, reverse the removal procedure.
be patient during these procedures to not damage the trim panel...they cost $150>275 ec........GL hope this helps
