After printing one or two page the printer starts to print half page even I order to print more pages it print only half page
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
SOURCE: Kyocera FS-c5030N printing pages yellow
Push in the charge corona assy. Its behind the left door. Each color has a cleaning rod and charge assy. I've seen this more than once.
SOURCE: the printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Testimonial: "Thank you so much, I no longer have a problem. It seems such a simple solution now I know the answer! I thought it was something major."
SOURCE: KYOCERA FS C5030N PRINTS ONLY THE FIRST PAGE OF A
make sure you are using the KX PRINTER DRIVER first
if so..
tray changing the pdl format
in the printers and faxes area right click on your printer
right click go to properties.
click on device settings tab (you have this if you are using the KX driver)llhopefully you are
you will see a button (pdl) click on pdl
changed pdl to pcl5e
good luck
SOURCE: Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
