Norstar m7310... tried to reset password using feature 983, now can't get any feature numbers to work. I dial feature 9 8 and the display goes blank. Any suggestions?
Yes it is feature 981 after you get the screen to show something like pass word then log in to it the when you press 8 then 4 you can the change your password.
Dial Feature 985 When the display changes to say SET something, dial 9 it'll prompt for a password, dial 73738767793 it'll ask if you want to reset the password, say YES then you'll be able to login with feature 983 1020000
To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
It sounds like you've either deleted your own mailbox or reset the password to 0000 and changed the password to the administrator mailbox. To reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000. 1020000 if you have 3 digit intercom numbers. Once that's done you can go into admin programming to default your password back to 0000.
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000.
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
to reset the administrator pasword enter feature 985 press 9 at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try feature 983 120000 ok again.
1. Log into system administration
To Reset a Mailbox Password:
2. Select the softkey under “MBOX”
3. Select the softkey under “Chng”
4. Enter the mailbox number you want to reset the password for
5. The display shows “Reset Password”
6. Select the softkey under “RESET”
7. Press the release key
*The new password will be “0000′, the system will ask the user to change
How to Change a Mailbox Password
1. To access the voice mail system press "Feature". 2. Press "983". 3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers. 4. Press "OK". 5. Press "MBOX". 6. Press "CHNG". 7. Enter the mailbox number you wish to reset. 8. Press "Reset". 9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
After you dial Feature 9 8 1 and type in the password, if you press the number 8, this will get you into the admin for your mailbox; where you can change the password, name, and greeting, just listen to the prompts.
Hi Carrie,
Sorry I have been installing a system in a remote area and they do not have Internet access as of yet. Here's what you need to reset the System Manager Password,
Feature 9 8 5, display will read " Set : ### ", press " 9 ", enter the following using the dial-pad: 7 3 7 3 8 7 6 7 7 9 3, display will read: " reset password? ", press YES, press RLS. This should fix the logging in problem. Let me know, ....Mike
