Apple iPad 64 GB WiFi Logo
B
Brenda Smith Posted on Nov 13, 2014
How do I show who is online on my chat sidebar?
I have an iPad 2. How do I get it my online chat friends that are online to show up on my side bar?
I can't load words with Friends 2 on my new Ipad. Any advise. it shows the screed but will not open up
Uninstall Words with Friends 2 and then clear the cache and any remnants of that game from your iPad. Then restart and install the game again.
Wanted to transfer from an iPad mini two to an iPad 4
It's easy. There takes transferring music as an instance. Just follow the below steps.
Step 1 Start Leawo iTransfer
Connect old iPad to computer via USB cable. Start Leawo iTransfer on your computer. The software will automatically recognize your device and shows iPad library in the left sidebar.
Step 2 Select music to transfer
Click the name of iPhone and go to "LIBRARY > Music" in the left sidebar and select multiple songs in the right interface by holding "Ctrl". Right click them to choose "Transfer to > My Computer".
Step 3 Transfer music from iPad to computer
In the pop-up window, chose "Save to folder" and click on "Change" to select an output directory on your computer. After that, choose "Transfer Now" to transfer music from iPad to your computer.
Step 4 Transfer music from old iPad to new iPad
Disconnect iPad but connect new iPad to your computer. Go to "iPad > LIBRARY > Music" in the left sidebar. Choose "File > Add > Add File or Add Folder" in the top middle to upload music you just transferred from old iPad to your new iPad.
For more details, check: How to Transfer Music from iPad to iPad
Why isn't my iPad syncing with my iPhone all of a sudden? In the past I was always able to have it working. I even turned off my iPad.
There are different reasons for this issue. However, there is a great way to solve it. You can resort to this iPhone transfer software - Leawo iTransfer to sync iPad with your iPhone. Just follow below steps.
1. Run Leawo iTransfer after installing it on your PC, then connect iPhone and iPad to computer with the USB cables. The software will automatically detect the libraries of your iPhone and iPad, show the libraries of your iDevices in the left sidebar. Choose one library and the contents will be displayed in the right part of the window.
2. If you want to transfer all the files in the library from iPhone to iPad, you only need to click the transfer button at the right bottom of the window. If you only want to transfer certain files, you are able to hold "Ctrl" key and choose files, then right-click the selected files and choose "Transfer to > iPad".
3. After choosing files, you will see a pop-up dialog. Click "Transfer to List: iPad" in the dialog and then click "Transfer Now" at the right bottom of the dialog to start syncing iPhone to iPad. You will see "Save to Folder" option below "Transfer to List" option, you are allowed to transfer files from iPhone to computer by checking this option.
4. The software will start syncing iPhone to iPad after you click the "Transfer Now" button. The progress bar in the dialog will show the percentage of the process, and when the process is done, you will find the files in your iPad. You are able to check them in your iPad, or in the iPad library within the software.
For more details, check: How to Sync iPhone to iPad
I need help with the passcode for my ipad
Is there anything wrong with the passcode? If your iPad is locked and you forget the passcode, please follow the steps below to unlock it.
1.Connect your iPad to your PC or Mac.
2.Select your device in the iTunes sidebar, and click the"Summary" tab.
3.Click "Check for Update". iTunes will show you if there any new version of iPad software is available.
4.Click "Restore iPad". You can finish the restore process by following the instructions given. During the process, a recommend that tells you to back up your files will be given. You can restore your data after the process is complete.
Now, you must have restored your iPad.
Note: Even you bring your iPad to the Apple service center, Apple staff also need to restore your iPad to unlock it. That's to say, you need to erase everything on it.
http://www.leawo.org/tutorial/forgot-ipad-screen-lock-password-how-to-recover-data-from-locked-ipad.html
How do I delete a blocking sent email on my ipad?
This is one way I've found to delete an email stuck in the outbox (which is what it "sounds like" you are asking...)
1. change ya smtp settings so the message defo wont send!
2. send a test email to anyone
3. it will attempt to send but oversiously fail...
4. hopefully the outbox should be listed with 1 message waiting to go out...
5. if not, try going into the Activity Window and canceling the send command, that should show it up...
6. click the Outbox and the will be one message listed...
7. goto View -> then Show Favourites Bar
8. you should see a favourites bar appear...
9. simply drop and drag the Outbox into your favourites bar...
10. if you restart ur laptop or close mail and then the Outbox has disappeard, simply click the Outbox in you favourites tab and woop woop it should appear in the Side Bar
2answers
My apple ipad wont charge or turn on
With iPad Magic, you can transfer photos, videos, music, books, etc. between iPad, iTunes and computer at ease. Moreover, it also enables you to convert audio and video files, rip CD and DVD discs, download online videos, make ringtones and more. Also, it works well on iOS 7 and iTunes 11.
http://www.youtube.com/watch?v=8ALYybIAL3k
Supported iOS Devices:
iPad, iPad 2, The New iPad, iPad mini, iPad with Retina display;
iPhone 3G/3GS, iPhone 4/4S, iPhone 5, iPhone 5C, iPhone 5S
39helpful
5answers
When keyboard comes up on IPad, the space bar is missing. I know that it was there at first. How do I get it back?
What app are you in? The iPad's software keyboard is not always the same - it changes depending on what context you're in. For example, it will remove the space bar and display web symbols when typing a URL (web address).
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
