Samsung Chromebook Series 3 XE303C12 Logo
d
dave haney Posted on Nov 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to download from flash drive onto a chromebook the easiest way possible
Friendly PC Repair
Level 3:
Genius:
  • Samsung Master 1,274 Answers
  • Posted on Nov 12, 2014
Friendly PC Repair
Samsung Master
Level 3:
Genius:
Answers
1274
Questions
Helped
262093
Points
3736
Http://kb.sandisk.com/app/answers/detail/a_id/15839/~/transferring-files-from-memory-card-or-flash-drive-using-chromebook
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Acer chrome book white screen
The Acer Chromebook may boot to a white screen with the Chrome logo due to a recent update. At this state, the Chromebook downloads and installs the update, and then boots normally within 30-40 minutes.
If there is no updating process going on and the Chromebook boots to a white screen, the following steps should help you resolve the issue. Keep a 4 GB USB flash drive and a computer connected to the internet ready.
  • Press and hold the Esc and Refresh (F3) Keys. Simultaneously press the power button. The Chromebook boots to the Developer mode.
  • Note down the model number displayed at the bottom of the screen.
  • Insert the USB Recovery Flash Drive into your Chromebook.
  • Wait for about 10 minutes while the system recovers from the USB flash drive.
  • Disconnect the USB flash driver once the recovery is complete. The Chromebook restarts automatically.
  • Follow the prompts on the Welcome screen.
Hope the above steps help you resolve the issue. For instant support Call Our Toll-Free 1-866-293-9220
2answers
How do I prepare a Samsung Chromebook to work with a Blue Intel QX3 microscope when the computer does not have a cd drive?
First please realize that a Chromebook is not the same as a Windows laptop/desktop and your microscope will most likely never work on the Chromebook. This is because we are talking about two different operating systems, with the Chromebook having a very slim Google operating system, called Chrome OS, designed for mainly web browsing and using web based tools such as Google Drive.
You can try to find a driver for the microscope that you can download from the web straight onto the Chromebook. BUT remember, the driver HAS to be for the Chromebook. A Windows driver will not work!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
2answers
Need to download from flash drive to Samsung chromebook
If your inser USB dive and your Samsung won't recognize and open it, there are two possiblilies: Your flashdrive has some problem or the USB port of yor samsung has some problem. so check port with another flash drive and check your flash drive on another computer. If you have some problem with samsung, claim your warranty
User Manual for CBS-111-C8UB
Hi there
The Acer site doesn't own up to a chromebook designated CBS-...... It does however have a CB5-111. If you go to the link below it will take you to a page of the Acer support site. If you click on "select my product from a list" you will get 3 columns. In the first click on "Netbook, chromebook", In the second click on "Chromebook 13 " and the only entry in the third is "CB5-111". Click on this and scrolling down the page will give 6 column headings, the second of which is "Documentation" Click on this and then click on the "download" button at the end of the User Manual line and this will be downloaded onto your computer in pdf format which can be saved to your drive for future reference
Drivers and Manuals
Cheers
Samung chromebook xe303c12 turns on to white screen chrome screen then turns black with power light on
Here is a trick you can use: You can put the Chromebook into Developer Mode, then once it is in Developer Mode you can switch it back into normal mode and it should totally wipe the Chromebook without requiring any USB flash drive or any SD flash card etc.
But remember that just like a Powerwash or a USB ChromeOS restore, this process will wipe all local files you have stored on your Chromebook's SSD.
best of luck ! And be certain to return to let us know if this helped.
-JW
PS: Remember that when using a Chromebook you should never store important files locally on the SSD HardDiskDrive shelf; Instead, store them in your Google Drive or if you must store them locally use something like flash storage media. A Powerwash or a switching into Developer Mode will wipe all SSD local files.
https://support.google.com/chrome/a/answer/1360642?hl=en for Samsung Chromebook XE303C12-A01
  1. Press ESC + Samsung Chromebook Refresh key + POWER. The screen displays a yellow exclamation point (!).
  2. Press CTRL + D to begin dev mode, then ENTER. The screen displays a red exclamation point.
  3. Press CTRL + D, then ENTER. The Chromebook deletes its local data, returning to its initial state. The deletion takes approximately 15 minutes.
  4. When the transaction completes, press the spacebar, then press ENTER to return to verified mode.
Can you download pics from a olympus tg810 onto a xbox 360?
Yes you can the easiest way is to plug a usb flash drive "at least 1GB" into your xbox 360 find it on settings tab >Storage... format it if it isn't already when it is formated remove from xbox 360 plug both usb flash drive and camera into pc/laptop then copy photos from camera onto usb flash drive. after your finished remove usb flash drive put it back into xbox 360 and you can move them to or from any formatted storage device including you hard drive
Can someone please tell me in as much detail as possible exactly how to complete the Wifi update. I have not done an OS update, and would like to avoid that if at all possible. Also, can someone answer...
Also, can someone answer if it is ok to download and upload the Wifi update onto my smartbook with a usb flash drive instead of an sd card?
Sure, this is possible.
How 2 delete u3 programs on flash drive
i have the same flash drive it just depends on how much gb u have and yes u should be able to just instull it directy from ur computer to ur flash drive just mess around with it try samller things onto ur flash drive
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
