I have pluged it in and all it does is all the buttons keep flashing and nothing happens
1. Press the auto off and small cup at the same time. Then Immediately release and re-press the small cup three times.
When it works the only light showing will be the descale light.
2. Press the small cup button then auto off button then release small cup and then auto off, when this works the lights on will be the power button light and the descale light.
ALL OF THE ABOVE DURING THE PROCEDURE MUST BEEN DONE FAST OR RAPIDLY.
3. When both of the above lights are on,(power and descale), unplug for about 3 to 5 seconds... and plug back in. The brewer should come to life and work normally.
Below is the address and Phone number to Keurig warranty service.
Keurig, Incorporated
101 Edgewater Drive
Wakefield, MA 01880
1-866-901-BREW (2739)
Follow this instruction step by step.
1. Turn Off
printer, cable power still plug in.
2. Press
Stop/Reset button, don't release the button.
3. Press Power
button by holding without release and than release Stop/Reset Button.
4. Press
Stop/Reset button two times (2x) now release the Power Button.
5. Wait until
service mode to zero (0).
6. Turn off
the Printer, cable power still plug in.
7. Press
Stop/Reset button, don't release it.
8. Press Power
button don't release & than release Stop/Release button.
9. Press
Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off
printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
With the igniition off, press and hold the odometer button, turn the key to the "on" position, but do not start the car. Keep the odometer button down until the oil light begins and ends flashing. Turn the key off, and then start car to see if it worked or not.
