Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
T
Tashia Asher-Echols Posted on Nov 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have plasma hd. And pink round pixels appearing in screen. They mve location and seem to be completely random. Still see picture on Tv with the pink dots everywhere. Any clue why
Electro Med Services
Level 3:
  • Sylvania Master 6,694 Answers
  • Posted on Feb 21, 2015
Sylvania Master
Level 3:
Answers
6694
Questions
Helped
1872487
Points
21433
Can be because of the bad connection between the plasma panel and drive board.
check the video hope it will help you
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
1 Related Answer
gemagm
  • 689 Answers
  • Posted on Nov 14, 2014
SOURCE: Pink dots and yellow blobs appearing on top of picture. Random locations of dots every minute / changing bug more dots randomly on bottom of screen.
May need to readjust voltages to the PDP. be sure to copy the original settings before you adjust any of them as you will need this reference point. If that doesn't help may need X or Y PCB. as last resort the PDP itself may be the fault.
TV showing color pixels but no picture and no sound
Well at least you didn't pay for the TV. Your panel is defective. Cheaper to buy a TV than to fix.
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Hitachi 55HDS 55 Inch Plasma Picture Problem
Hi Mhansen884,
This type of failure is due to a defective upper and lower scan boards.
Check the link provided to see what the parts look like and or to find the part numbers if you would be DYI,
4helpful
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
2answers
Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Onece the plasma heats up it shrinks a little, i think the cause is that you are low on plasma, so when i heats it shrinks and since the plasma cycles, the area low on plasma wil move slowly around the screen, take this to a repairman and more plasma can be added to it.
Problem with samsung plasma tv
hello ive just bought a samsung plasma off my friend and its about a year old and yesterday i set it up and get a fine picture untill about a hour or so of being on it starts geting blue sparkles round the outside of the tv mainly on the left side and seems stronger when sport is on ive tryed doing different things but nothing seems to work?i have also bin told that plasma tvs have to have gas put in them every so often is this true?i dont no which samsung model it is but it is 42inch and is full hd ready and is black with the round circle on the front of the tv can you help me?
Hp 42in plasma tv
There is some voltages that need adjusted in your tv and possibly the z sustain board needs replaced if the voltage adjustment doesn't fix it.
3helpful
4answers
Pink pixels across plasma screen.
I have the something going on w/mine!!! Are your fans turning on?Mine are not.I think that's my problem...Get back w/me..thanks,jon.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
