What to do to fix my tablet that won't stay on after releasing the power button
I charged my tablet that had ran completely down and when I started it up it would not stay on after releasing the power button.I tried a reset but this didn't help. As long as I hold the power button it will stay on but when I release the power button it goes off. HELP!!!!!
Re: what to do to fix my tablet that won't stay on after...
If it doesn't stay on , you may have a broken battery . If you're out of warranty, somebody has to open the device and replace the logic board. The part is available on ebay. On youtube you will find a guide on how to disassemble an Insignia tablet. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third partyInsigina Repair Services.
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
It's actually very easy, once you know how to do it. Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Sounds like you are caught in a Bootloop for some reaso. Press and hold the Power Button for 40 seconds, release. Then plug the device in a charger, let charge for 4 hours while powered down. Unplug the device from the charger: Step1 : Press and hold the Power Button for 30 seconds, then release the power button. Step 2: Press the power button for 1 second, release and press the power button again, release. Step 3: Is the device booting normally? If no, contact the manufacture for a replacment.
Her is a possible solution: 1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours. 2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3. 3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger. 4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours. 5. Unplug the Kindle from the charger. 6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7. 7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable. There is a solution to avoiding this but first get tablet started by: Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on. If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once. Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear. Open settings / display / sleep. I set mine for 30 mins. Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start. Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
