To solve you oregne light problem you must do this press power bottom for few seconds to make it flashing Orange this means that the machine is now in descaleing mode then do the descaleing product be sure you use dolce gusto descaleing only after you done reset power bottom this should solve the problem.that was a working for descaleing
HI THIS IS BECOUES YOU ARE DUE TO DO DESCALE .DO DESCALE ONLY WHEN YOU PRESS THE POWER BOTTOM FOR 5 SECONDS TO GET THE MACHIEN INTO DESCALING MODE .SEE THAT YOU GET DESCALING FOR DOLCE GUSTO ONLY IN SIDE YOU HAVE AL THE HALPE YOU NEED
Sorry chaps, all these suggestions are wrong. The orange light on the small cappuccino button means the unit needs to be descaled. See Nespresso support to download the user guide and you'll see this explained there
I had the same problem too. Do repeat the descaling with water only. After the descaling the Lattissima shuts down. Just wait some time after shutdown before restarting the Lattissima again. The orange light will be turned off. Hope this helps you too!
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
