If you have a primer bulb and the motor "recovers" after a near stall with a pump of the bulb, then you have to replace your fuel pump. Johnsons do have this problem often. Otherwise it could be the high speed jets although it sounds like you checked the carb good. Also if you have a primer bulb, Replace everything from the tank to the engine. Costs about $14 at Wal Mart, $55 at a boat place.
REEDS YES, COULD BE REED OR SEALS,BUT LETS GO TO THE BEGING #1 POWERHEAD BOUGHT IN PIECES THEY TOR DOWN, WONT IDLE NO POWER, REBUILT POWERHEAD REEDS LOOKED GOOD,NO LUCK WONT IDLE NO POWER #2POWERHEAD BOUGHT FROM SEAWAY. USED OLD INTAKE CARBS &ELECTRICAL STILL SAME NO IDLE AND POWER #3POWERHEAD I BOUGHT A RUNING 225 COMPLETE POWERHEAD USED WIRE HARNES & VRO FROM 200, RAN GOOD ONE WEEKEND , WENT ON VACATION WONT IDLE NO POWER. 3 POWERHEADS BASICLY SAME PROBLEMS REBUILT&USED WHAT KNOW
who built motor if crank seals are not good motor will not pull gas please dont leave me bad feedback im just tring to get an idea of where to start is the motor reed inducted?if so that would be a good place to start
