Bosch & Tankless LP Hot Water Heater  Logo
r
richard brackenbury Posted on Nov 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Find manual for 425 ng tankless
Looking for manual
bob_w_burns
Level 2:
New Friend:
  • Expert 81 Answers
  • Posted on Nov 11, 2014
bob_w_burns
Expert
Level 2:
New Friend:
Answers
81
Questions
Helped
19499
Points
145
Http://www.ps2netdrivers.net/parts/bosch.gwh.425.hn/
Can Richmond tankless heater which is now LP be converted to natural gas?
If it can, then it is done with dip switch settings.
Read your product manual.
Switching types of gas, and messing with dip switches is dangerous.
LP gas burns much hotter than NG, and LP pressures are much higher than NG
Call Rheem with serial number and they might supply the information to you, but will likely tell you to call service technician... leaving you in exact same spot you are in now.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have a Bosch GWH 425 HNO propane Tankless Water Heater which began intermittently exploding when demand for hot water occurs.
Call a qualified service tech immediately.
Gas explosion indicates dirty combustion parts, and gas is not fully igniting when tankless turns on the gas. So gas builds up and then explodes causing serious damage to tankless, and serious risk to homeowner.
I have a Bosch Tankless Water HEater Model GWH 2700 ES NG with an error code of A3. I was told to push reset and the problem would be resolved. This worked several times and now it doesn't work. ...
Yes. Contact Bosch.
Error codes are considered start-point for troubleshoot.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Tankless are complex electronic machines.
If on-site plumbers cannot figure out problem, then you need trained service technician with a service manual for your specific product, who can ohm-test the electronics.
Bosch will have a list of trained service technicians. And maybe Bosch has another step for fixing problem yourself.
Fix most tankless problems yourself, same day, for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
1helpful
Black soot on outside wall above hot air exhaust. Excess flame, incomplete combustion? How to adjust/correct?
All gas water heaters, tankless and tank-type, require cleaning burner and combustion parts.
Tankless manuals suggest once per year.
Tank-type once every 2-3 years.
Before calling service technician, open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/pdf/TWH-G1-13_Removing_and_cleaning_burners.pdf
Burners do not operate cleanly:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BOTechSupport/Troubleshoot/tabid/602/Default.aspx
Gas outdoor mounted AQ250 won't stay lit. Unit is about 2 years old and has been working great.
Before calling service technician, open following link for Bosch troubleshooting resources.
Sample manual has troubleshoot section and yearly maintenance requirement.
http://waterheatertimer.org/pdf/Bosch-250SXO.pdf
Service bulletins for 250SXO
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXOTechSupport/ServiceBulletins/tabid/573/Default.aspx
Tankless require yearly maintenance as outlined in manual.
No tankless manufacturer suggests do-it-yourself repairs on their product, in part for liability and danger to customers, but for long-term customer satisfaction.
Repairs and yearly maintenance will eliminate the $1-8 monthly energy savings expected from owning tankless.
I have a Bosch GWH 2700 CTDR EFS NG and the water will not get hot and if it does, it's only for a brief moment.
A lot of factors, internal and external, can cause this problem ranging from bad PC board to plumbing problem.
Since you have no error code, it could be plumbing,
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Open following link for useful Bosch troubleshooting information including Bosch support and typical manual for 2700 gas tankless:
For folks with Rheem tankless:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Error codes re: fan speed fan very noisy
I was looking for a service manual, which you apparently do not supply. I was not looking for someone who will charge me a fee to get information. I can get that info directly from Bosch for free. Thank you for answering. John
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Top Bosch Water Heaters Experts
john h
ZJ Limited
ZJ Limited
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
