It is not working and want to send it in for repairs
SOURCE: Nikon ProStaff Laser 440 not working
Here is the address to send your rangefinder for repairs.
I had the same issue with my Nikon Laser 800 rangefinder. I sent it in and they wanted $311.00 to fix it so I bought a new one for $300.00 off EBAY. Today I was missing around with my old rangefinder and noticed after I put the battery in I could hear something loose in the rangefinder. There is a little metal tang in the bottom where the battery goes that holds tension on the battery that was bent down. I bent it back up about 3/16" and put the battery back in, now it works fine.
SOURCE: need the proper tool for a nikon prostaff range finder
Harbor Freight has a kit that has them in it and most industrial tool supply companies have them. It's a security screw. there are many kits availably with an assortment of bits in them. Drill Master has a 100 piece kit that's pretty cheap. Item#91310
Testimonial: "Perfect. Huge Help. Thanks"
SOURCE: MY NIKON 550 RANGE FINDER
Same problem. Conclusion: just because it has the NIKON name does not mean it is not a piece of Chinese junk.
SOURCE: need battery cover for my
This part is often available on ebay.However, as of now, it is not available for this model. The only option is to contact Nikon for the same. It would take around 2 weeks for them to ship the part. The cost of the part is around $15 and they have shipping and handling charges worth $45. The contact number for parts section for Nikon is given below :
Contact Nikon Parts Department
Phone: 1 310 414 8107
Fax: 1 310 322 6979
7am - 3pm PST Mon - Fri
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: I have a nikon LR 1200 golf range finder that will
Hi Bobby,
This seems to be a problem with the laser alignment , which has gone out of order due to change in temperatures and other external factors.
I would suggest you to reset your device , by removing the batteries for at least 5 mins and then putting them back in.
Also make sure there is no blockage in front of the rangefinder , like a strap for example.
Changing the targeting mode can also help you remove the problem , try doing it.
If this does not work , then in such cases people either like to repair the device or get a new one , by comparing the cost that is incurred.
Hope this helps ...:)
