Connecting your xbox one console to a sound system. this setting allows you to adjust how much the volume change on your tv using the volume up or down.
hook your dvd player up to the tv via hdmi, then take the optical audio output from you tv to the soundbar. Make sure to enable to audio output jack in the tv setup menu as some manufacturers disable this jack by default.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar. Or From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
Sometimes you have to enable audio outputs in the menu on the tv. Not all tv's have output for sound either. Haier is not a premium brand so don't expect to many features
You don't identify your make and model of MP3 player or your Flat Screen TV.
Some types of MP3 player can dock into a device (MP3 Dock) that has audio output connectors that can connect to either your TV or your Sound Bar with either standard stereo phono or HDMI cables (your TV has HDMI capability).
If no dock is available for your MP3 player, a stereo phono to 1/4 inch stereo jack will connect either audio Out or Headphone Socket to your TV or Soundbar. The sound quality may not be the best with this type of connection but it should be adequate.
A retailer like Radioshack, Best Buy, PC World, Maplin, etc. (depending on where you are) should stock these MP3 Docks and cables.
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
