Hi I have a 24i worcester boiler I have drained the heating to do some work but I need the hot water to still work.I spoke to Bosch and they said I need to put a loop in.I am not a plumber but can get by can anyone tell me if there is an easy way round this or can I just leave rad valves shut and that would work. THanks
Hi Steve, I am not a plumber but have done a lot of DIY on my own heating system with Worcester Bosch combi boiler! I believe that you can have the hot water on without the heating system filled, just turn all the settings as for summer use and the thermostat right down so the heating is forced to stay off!
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
SOURCE: flashing red light on Worcester 24i junior combi boiler
Pressure is ok? at 1 bar or above
I think on this one there should be a reset button [red] on the left hand top of the casing - or lower the control panel [ phillips screw on each side] and the button is on the left of the base plate. Press this and try the heating.or hot tap
P.S. if you're on a prepayment meter check you have gas.
Testimonial: "Thank you, very helpful advice. Still got the plumber coming to check everything over but the boiler is up and running for now. Thank you so much"
SOURCE: My boiler is not working, not heat, no hot water,
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
SOURCE: Worcester Bosch Highflow 400 Boiler - no hot water or heating
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hi, this is Worcester, Bosch Group
Although we don't currently offer live technical support online, our Technical
Support department will be able to help. Their number is 0844 892 3366 -
they're open 6 days a week and on average answer calls within 20 second. If you
want to know more about our Technical Support department visit our website
http://www.worcester-bosch.co.uk/homeowner/customer-service/customer-technical-support
We look forward to helping you
SOURCE: worcester 24i combi boiler loseing water from
http://www.plumbnation.co.uk/site/worcester-greenstar-junior-24i-combi-boiler-natural-gas/
Annie, I don't have experience in this boiler , but I found a link that has some information and numbers to get help. Thought I would pass it on and hope it will be helpful.
