Sanyo em-s1298v microwave oven
SOURCE: Sanyo EM-G2585W 800 Watts Microwave Oven
It's possible that the unit is overheating, and shutting itself down to make sure that it doesn't melt or burn. Do you have it against a wall, or in a cabinet where the unit cannot vent? Is there a fan? Is it working? --j.
SOURCE: Sanyo microwave mod # EM-2100GS
unscrew the unit replace fuse near the transformer. this fuse is for heating....
SOURCE: new oven door needed sanyo EM-SL100N
That would be a UK model. No wonder I had so much trouble finding it.
You can get parts here:
http://www.chsinteractive.co.uk/microwave_ovens_parts/
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: turntable on my sanyo EM-C6786V
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If
yours is not set to be off via the control panel, and it won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven. In some brands, you have to cut the motor cover off with snips, then use a
screw when reassembling it.
You can find Sanyo UK support, parts and authorized servicers here.
SOURCE: is it possible to download the user manual for
Look up " http://sanyoservice.com/osb2/itemdetails.cfm?ID=1202 " on your
computer. If you can read and download a pdf file you'll have your manual.
