SOURCE: Replacement Mitsubishi lamp busted again in less a year!
A Halogen lamp is a Halogen lamp. They are designed to last between 3000 to 5000 hrs.
You got a much longer life than expected on
the original lamp.
SOURCE: have a blue spot on the screen. started just
Hi,that's an issue with the light engine.Basically there's 3 chips blue,green and red they create the image on the tv ,when they start to fail you'll get those spots all over, mostly in the corners.God bless you!
SOURCE: bright white spots on mitsubishi wd-73833 I just
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
SOURCE: my mitsubishi 60 inch projector
Replacing the Light Engine is the only remedy. Cost is usually in the area of $900-1100 dollars.
SOURCE: 60 inch mitsubishi tv has white spots all over the screen
White spots mean the optical Light Engine is bad.
