Timex Sports Ironman Triathlon 100-Lap 66801 Wristwatch Logo
j
james Boucher Posted on Nov 06, 2014
I replaced the battery and now the chime does't work
Straussburg Manor chime clock doesn't work even after replacing battery. Any tips to troubleshoot?The clock was obtained via auction. Tried manually swinging the pendulum, but it always stops.
Troubleshoot the issue. Here are some steps you can take:
Check the Chime Selection Lever:
Ensure that the chime selection lever is not set to the "silent" position. Sometimes, accidentally setting it to silent mode can prevent the chimes from sounding.
Inspect the Cam with Humps:
The Westminster mechanical clock has a cam with humps on the front plate of the movement. These humps control when the movement stops chiming.
Run the chime by turning the hand (you can mount it with the nut, but it's not necessary). Observe the cam with the humps spinning.
Wait until it reaches the end of the smallest hump (which represents the first quarter, the shortest chime).
Stop the gear train from moving with your fingers and hold it.
Adjust the hammers from the back of the movement to match the position where the last hammer drops after the 1-2-3-4-5 hammers strike in a row, representing the end of the first quarter.
Tighten the cam so that the bar riding the cam is just after the smallest hump. This should set the chimes correctly.
Battery Replacement:
If you've recently replaced the battery, ensure that you've used fresh C batteries with high capacity.
Batteries should be changed annually to guarantee accurate timing and consistent chime sounds.
Low Battery Warning Function:
If your clock starts behaving irregularly or the pendulum stops (if equipped), it might be due to low battery. Install new batteries to resolve this issue.
Remember, these are general guidelines, and specific models may have additional considerations. If the problem persists, consider seeking professional assistance or replacing the movement if necessary. If your clock is chain-driven, you can order the 1161-053 movement from Clockworks when you're ready to swap it out.
Feb 15, 2024 • The Watches
We have a Acctim barrery operated westminster chime wall clock and cannot get the clock to work, pendulum & chimes work but not the clock, is there a reset button,how do we get it working. it is 11yrs...
Press the red button at the back and go through all the hourly chimes until you get to the next chime due i.e. if its 3.15 whebn your doing this, only go through the chimes until 3 o'clock and no further. Then turn the hands clockwise ONLY never anticlockwide and she should be fine.
Nov 19, 2010 • Watches
Adventure tech doesn't have chime
could be following reason
1, you did not put case back correctly,
2, small spring which connect watch movement from caseback for chime lost during battery change ,
3, may be required reset of AC & Battery plus ,, by twizer
hope this help
AmFix Jewelry & Watch Repair
203 N. LaSalle st
Chicago, IL 60601
Ph: 312 641 7000
email: [email protected]
web: www.goamfix.com
Replaced battery- alarm won't chime anymore even though "ON"
I removed the battery myself, and underneath are 2 metal prongs. One was bent down and not touching the battery. I pulled both of them up so they would touch the battery, and now it works fine.
Indiglo backlight works, but beep/chimes doesn't
There should be a RESET switch right beside the battery slot. It is usually either the 2 pins that allow the battery cover to hinge up or down, or a metallic strip right beside the hinge. You will see the word RESET underneath the metal strip with a small round metal piece right below it. You need to take a small jewelers screwdriver and push the metal strip down to make contact with the small round metal piece. This will reset everything back to working order. You can then go ahead and set the time, date, etc. Sometimes it is necessary to reseat the battery and do the RESET one or two extra times but it should reset. If after all these steps you still can't get your chimes to work you may have to get your watch looked at.
6helpful
2answers
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
4helpful
2answers
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 • Watches
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
