XO Vision Ematic eGlide 7Inch Touch Screen Tablet with Android 21 Black Digital Picture Frame Logo
L
Lisa Posted on Nov 05, 2014
How do I store downloads to sd card
What are the steps to have all downloads save to the SD card?
Curtiss Cott
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 05, 2014
Curtiss Cott
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
107
Points
Under SETTINGS. APPLICATIONS. MOVE TO SDCARD.
Each App may also allow you to choose where it stores it's data.
2answers
Can i transfer my deezer music playlist to my sd card on my tablet and how to do this.thanks
You can do that! Here's a simple guide:
Download Deezer Music to SD Card on Android
Deezer offers different options for users to listen to music. When you sign up for Deezer Free, you can browse 90 million songs with the Deezer music app on your device, but you cannot enjoy offline Deezer. If you're a Deezer Student, Deezer Premium, Deezer Family, Deezer HiFi, or Deezer Family HiFi user, you can download your favorite content to listen to offline. As only Android devices support SD card, you can download your favorite tracks from Deezer to an SD card on an Android device.
Step 1. Open the Deezer music app on your Android device and locate the Home screen.
Step 2. Go to Settings > Other > Storage and select the SD card to save the downloaded Deezer songs.
Step 3. Press OK to confirm your settings and go back to your music library in Deezer.
Step 4. Select your favorite tracks, albums, or playlists and tap Download to download your liked content to the SD card.
How to Transfer Songs from Deezer to SD Card on Any Device
In fact, you are only allowed to download songs from Deezer to SD card on those devices which has an SD card slot. Otherwise, those downloaded Deezer music tracks are streaming content and cache files that are not playable on other devices without the Deezer music app. And once stopping subscribing to Deezer, you cannot continue to enjoy those downloaded songs.
To break those limits, we'd suggest that you use a Deezer music downloader to save Deezer songs to an SD card. Here you cannot miss this tool called Tunelf Deezer Music Converter . It is specially designed for all Deezer users and can download tracks, albums, audiobooks, playlists, and podcasts from Deezer. As it supports six popular audio formats, you can choose to save Deezer music to MP3 and then transfer songs from Deezer to your SD card.
Step 1 Import Deezer Music Tracks to Tunelf
If you have the Deezer music app installed on your computer, then you only need to launch Tunelf Deezer Music Converter first. And go to Favorites and select Music to view all of your favorite tracks, albums, or playlists in Deezer. After finding tracks you want to download, copy the music link and paste it into the search on the converter.
Step 2 Set the Output Format for Deezer Music
Importing Deezer music tracks to the converter is followed by the settings of the audio parameters. Click the menu bar and select the Preferences option from the drop-down menu. There will pop up a window where you need to set MP3 as the output format and adjust the bit rate, sample rate, and channel. Then click OK to save the settings.
Step 3 Download Tracks from Deezer to MP3
To make Tunelf software work, click on the Convert button at the bottom right of the corner. Wait for a while, and Tunelf Deetrack Music Converter will download and export Deezer songs to the default folder. Or you can change the storage folder in advance. By clicking the Converted icon, you can view the converted music in the history list.
Step 4 Transfer Songs from Deezer to SD Card
Now you need to connect your SD card to the computer and transfer those Deezer songs downloaded by Tunelf software to the SD card. All the limitations from Deezer music have been removed by Tunelf software. Then all the music can be played from a number of music players or devices from your SD card.
1helpful
I have put 32 gb sd card into excelvan tablet for external storage and its not saving?
Unfortunately, most apps will not load onto an SD card. You'll find that some apps will, if a card is installed, place data there. Mostly the SD Cards are installed for use in storing photos and videos taken by the user with the tablet camera. Newer tablets and smartphones are coming with more and more internal RAM to alleviate the "full" issue, but in most cases, you wither have to give up the new app, or remove one to get another.
How do i set my tablet to auto save to my SD card
There are several methods to help you set download application path to SD card by default.
Please follow the steps given below,
Method 1:
- Insert the SD card into the device, Touch 'File Browser' on 'Home screen'.
- Tap 'Apps', On Apps, select the 'App to be installed'.
- Tap OK to install the App to SD card.
Method 2:
- Tap 'Settings' on 'Home screen'.
- Tap 'Storage', Check to turn on SD card, and set 'SD card' as the default storage place.
Method 3:
- On your Android tablet or phone, tap the 'App drawer' icon from the home screen.
- From the displayed list, tap on the 'My files' icon.
- From the opened window, on the top right corner, tap the icon with four horizontal lines.
- From the displayed menu, tap the 'Settings' option.
- On the opened Settings window, under 'Select directories' on the left, tap the 'Set home directory' option.
- From the window that appears next, tap to select the desired folder or the entire external SD card where you want the files to be downloaded by default.
- Tap the Done button from the top right corner of the window when you are done.
GuruAid.com
1helpful
Have. Gigaset qv830. I've put in an sd card. When I download book to kindle app how can I save to sd card and not on tablet?
Go into "storage" in settings and then scroll down to the Kindle app. Select "move to SD card"
How to save downloaded apps to an external SD card?
open up file explorer first. than copy the files and paste them onto your sd card
How do I save apps to sd card on ePASSION 9" phablet
If you're running Android JB (4.0) or higher, the short answer is that you can not move apps to the SD card. The long answer is that you can manually move them using Root (KingoRoot Desktop works on E-Passion MTK tablets and Phablets, Framaroot works with some) at the cost of potential system instability.
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Acer sd card
are these movies brought from google play store if so these cannot be saved to the sd card
Transfer data from galaxy 10.1 note to sd ext storeage
Go to the play store and download a file management app. Use the app to move the files. OR, connect to a PC and manually move the files to the SD card
What does code 912 mean? i get this when downloading apps from apps store
There are a few reasons why you would get a 912 error when downloading apps.
  • Downloading apps directly to an SD card
  • Play Store (app store) needs to be updated
  • Bad cache
The following methods could help solve the problem
Clear Cache and Reboot
  • Go to Setting >> Go to Application Setting (In some devices application setting is named as apps).
  • Go to, All the apps > >Find the Google Play Store >> Clear Data and Cache
  • Once you have clear everything, Next you need to Force Stop the application
  • Also, try to clear Cache and data of Download Manager and Google Service Framework.
  • Now, Restart your device and try to download the app.
Unmount SD Card
  • Go to Setting >> Storage >> Scroll down and select "Unmount SD card"
  • Open Google Play Store >> Download the app again that was giving you the error message
  • After successful installation, Go back to Settings >> Storage >> tap on "mount SD card"
  • If above steps didn't work, also try removing your SD card before installing.
Move app to phone
  • Go to Settings >> Go to Apps >> Select, All the apps
  • Scroll down and select the app that was giving you the error during update
  • Select "Move to phone"
  • Open Google Play Store and update the app
  • After successful installation, you can move the app back to SD card
Top XO Vision Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a XO Vision Tablet and eReader Expert? Answer questions, earn points and help others
