I see lots of emails but the body or message doesn't appear.
If the lock with the circle is actually a circular arrow around the lock
Something like
it means that your phone is in Portrait Locked mode.
Will your phone go into Landscape orientation if you rotate the screen?
If this is the case then to unlock the orientation...
Double click the home button to bring up the multitasking bar.
Swipe left to right to scroll to the the orientation lock.
Tap it to lock or unlock.
Not sure what you mean about the messages.
It is called `portrait lock.` Pull up you bottom tray,by swiping upwards to get the bottom tray, then you will see the same icon, turn it off.
It just locks your screens orinetation.
Testimonial: "No, the icon with the little lock inside of a circle does not come up in respons to that maneuver. It is still there in the upper right corner of the screen. However, without my doing anything, the text of my emails has reappeared and the little lock remains!? So, my problemis solved but I haven't learned from the strange experience."
SOURCE: my iphone
hi this is for the first guy.or to ay1 thats upgraded 2 1.1.3 and wants to downgrade . in order to fix those errors u need to put your phone into a special dfu mode.. ul need ibricker 0.91
and firmware 1.1.1 download them both and put thm on your desktop this is for pc user's
plug in your iphone open up ibriker when it detects your phone
click on downgrade to 1.0.2. ur screen will go white this is the special dfu mode were after . then open up ituens hold shift and click restore a window will open up allwing u to chose what file firmware you would like to use to restore. go the desktop were u put the i.1.1 firmware and select that ur phone will restore dont worry about any errors or anything like that at the end.. but your still not done yet after this go back to ibriker if ur screen is red your fine. but if its green u have restore the firmware the same way again it usualy works the second time around
SOURCE: Why doesn't my iPhone let me recieve emails
in your iphone you can receive emails but not send them!
well you configure your iPhone!
