When I am not having this bobbin problem, the machine runs perfectly. I had my machine serviced a few months ago, too. The guy that serviced the machine told me not to oil the machine, is that correct?
Look in your sewing machine manual, see if it mentions oiling your sewing machine, if it doesn't then the sewing machine could be a self oiling from the factory,,self oiling mean the part were put in oil for a period of time and they won't need oiling, the more you sew then the oil will be released to oil the parts automaticly. sounds like you may need a new bobbin case, did the problem start before the machine was serviced or after?
SOURCE: SIMILAR PROBLEM OF TOP THREAD ACCUMULATING IN BOBBIN AREA
it sounds like a needle threading problem. if you have the instruction book, pull yout needle thread off the machine and re-thread as per the book ie presser foot up and make sure thread goes betwen tension discs and up over takeup lever.
to check needle tension is ok, lower presser foot and pull needle thread through needle, the needle thread should be tight enough to bend the needle a little.
goodluck,
scott.
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
SOURCE: NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Testimonial: "Thanks! I was hoping to avoid paying for a fix, but it looks like I have to **** it up. So much for being thrifty and restyling my clothes."
SOURCE: I have a Janome Memory Craft 3000 sewing machine.
Good day!!!
please apply a some oil on the motor and other moving parts inside you sewing machine..
After
that reboot the machine and used it....first try is persisted but when
you used it continuously for at least 10 minutes your machine is OK...
Go to http://fixsewingmachine.com since there is great diagram there to help you visualize the process. Jimmy
