Hi I have a similar pressure washer from Kartcher and the same scenario as yours I have owned it for about 2 years and noticed that it was getting harder and harder to start with each time I use it which is months. If your pw has a honda engine on it the likely culprit may be the carbuerator. The main and pilot jets may get clogged up with gunk from dired up gasoline. To see if you have a fuel problem spray a shot of starter fluid into the carberator with the choke open, then close it and try to start. If it runs for about a second and dies, then the carbuerator is at fault and you are not getting fuel into your motor and all you're doing is working out your arm.
A tough one. All I can suggest is check there are no blockages or crimps in the fuel line. When you say you pulled the cord and the engine doesn't turn, do you mean it doesn't start or the engine doesn't turn over? If it doesn't turn over when you pull the cord, that mechanism is not working.
