SOURCE: I have a model D-4 weaver rifle scope with missing adjustment par
Pretty much all rifle scopes have great warranties. Send it into weaver and i'm sure they will fix it plus replace any parts. I'm sure they will charge for missing parts but it would be best for them to look at it and check it out. TP
SOURCE: 30-30 winchester lever action model number 94ae
Take it to a reputable gunsmith or Auction house, they will be able to advise you.
SOURCE: How old is Remington model 572 Fieldmaster rifle
The serial number does not reflect the date of manufactuer, but there are letters stamped in the side of the barrel at the reciever, on the left side, they are a date code, I will give you an app, If there are more than a couple letters and numbers, it has been reworked by the factory. But none of mine have.
m=1921,,,z=1931,,, and all the letters in between there except for o and q are the years, then it starts again at A=1932, and goes to L=1942, then,,,MM=1942,,,NN=1944,,,etc to ZZ=1953,,,then it stats with A again,,through Z= 1975 and after that it a random of letters I,O, Q and V, to 1979, then A, again, to Z=2005, then it starts again. hope this helps.
SOURCE: I have a Model 61 serial number869950 that shoots
Check out this site here. Winchester 61 History. You can find which model you have. Hope this helps Fix Ya up.
SOURCE: When was Winchester Model 94 Serial Number 2057299 made?
1954
http://www.proofhouse.com/win/index.html
