The casing of my cell phone has broken from skrew jecks. from where can I get change its casing?
SOURCE: how to forward received sms and mms messages
If you wish to manage a specific message in the history, you can press and hold a message to bring up options such as forward and delete as well as view details. The options to copy the text of a message or edit a message have been removed.
SOURCE: my htc cell phone touch screen does not work
my htc cell phone touch screen does not work all a sudden
SOURCE: ON HTC WILDFIRE HOW DO I CHANGE THE RINGTONE OR
If you connect the phone to your computer and select 'mount as disk drive' when prompted, open up the removeable drive (your SD card) and put the music file you want to use into the 'music' file on the SD card.
Unplug the USB cable and go to 'music' in your phone. Select the song you want to use and then press menu, this will give yuo the option to select it as your default ringtone.
I havnt found a way for text messages sorry!
SOURCE: I am having htc wildfire. so i need pc suite for
hi,
Visit to the given link and download and install the "HTC Sync 3.0"...
http://www.htc.com/www/supportdownloadlist.aspx?p_id=316&act=sd&cat=all ...
hope this has helped you..
Please rate the answer.
Thanks...
SOURCE: How do I download my
Messages in phone are not lost when you change your SIM card but if messages are stored in SIM card, you can copy then to phone.
To copy SIM messages to phone do the following:
1. Open Messages
2. Press Menu and select settings.
3. Scroll down and select "Manage SIM messages"
4. Select Messages in SIM and copy or move to phone memory
Now when you change your SIM, these messages will remain in the phone
But, if you mean changing the phone, download a simple program called SMS backup & Restore.
It will backup your messages to memory card in a file. You can save the file on pc and restore your messages to other phone when you change your phone.
Here is Android Market Link to download SMS Back & Restore:
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore
Reply in case of any problem.
1. Power on your HTC mobile phone with an unaccepted SIM card in (or no SIM card at all).
2. Enter your 8-digit unlock code you attained earlier.
3. Your HTC mobile phone should be unlocked and may automatically reboot!
These free unlock instructions provided above only work with GSM or SIM card versions of the HTC Wildfire.
I think helps.Let me know
Chandrashekhar
