Question about AKASO KingPad 7 Google Android 4.1 Dual Core IPS Tablet MID PC, Rockchips RK3066 Dual Core Cortex A9 CPU up to 1.6GHz, 1Gb RAM, 8Gb HDD, HD IPS LED Multi-Touch Screen 1024x600, Front Camera Rear Camera, Google Play Pre-Installed, HDMI 1080P Output, Skype V
Table would not bootup. The word android keeps flashing on the screen, why?
I have tried several times to re boot. But each time the android logo keeps flashing on the screen. I have left it on for hours and nothing happens except the word android keeps flashing. I can get access to anything on the tablet.
    Sergeant:
  • 357 Answers
My KF froze the same way. I found a forum where others had same prob and got the fix-it from them. It entailed holding the power button for about 45 seconds when device was off.
Posted on Nov 03, 2014
SOURCE:
It is stuck on the logo android is there anyway to make the tablet work again
Second one in three days. Seems a know issue.
  • Android tablet stuck on Android Logo Fix - YouTube www.youtube.com/watch?v=B_bJeLnlClE
    • BY RICARDO GARDENER
    • 9 MIN
    • 237K VIEWS
    • ADDED 2014-08-13
    Video embedded · Learn how to fix your tablet that is stuck on the Android logo or ... Learn how to fix your tablet that is stuck on the Android logo or Android start ...
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung ... or it boots up to its Samsung logo then freezes, ... How to fix an Android phone if it is stuck or frozen on the Samsung logo
  • Stuck Android Logo - YouTube www.youtube.com/watch?v=w6tmETIerBM
    • BY KELLER KING
    • 5 MIN
    • 553K VIEWS
    • ADDED 2013-06-13
    Video embedded · This video will show you how to restore your Ekko Tablet T700 if it gets stuck on Android Logo. Este v?deo vai mostrar-lhe como restaurar o Ekko Tablet ...
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Tablet Stuck at Boot Screen. ... Samsung Galaxy tab 3 made in Korea stuck at android logo. ... T98G tablet stuck on boot screen.
  • Dec 29, 2015 | Tablets & eReaders
    USED WRONG CHARGER ON RCA TABLET AND NOW SCREEN MALFUNCTIONING.HOW DO I FIX?
    Try a factory reset of your tablet first. Here is a link to the procedure:
    http://www.rcatablets.com/how-completely-reset-your-rca-android-42-tablet
    Apr 29, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
    Get rid of dead robot
    try clearing your cache partition, you can get to the android recovery with your buttons.
    1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
    2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
    3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
    4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
    5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
    6. Use the volume buttons to move up and down through selection in this menu.
    7. Using the volume down button, scroll down to "Wipe data/factory reset"
    8. Tap Power hard key to select option.
    9. Scroll down to select "Yes, delete all user data".
    10. Tap the power button to select. Wiping and formatting data will take a few minutes.
    11. You will return back to the Android recovery screen menu.
    12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
    Jan 21, 2015 | Tablets & eReaders
    I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
    Oct 29, 2014 | Tablets & eReaders
    I tried reseting it cos it was telling me my firmware was corruped. after reset, i powered on and i came on! but the only screen that apper is the welcon screen and nothing more. so i treid hardreseting by...
    So sorry to hear/read about this challenge you are having.
    You've provided a few details to help you out; so also is it that you've probably left a few otter details out too.
    First, the android logo which appears... is it lying on its back with its tummy open and a 'no command' writing also displayed?
    Or is it simply the android logo ONLY.
    In any case, once you do the hard reset and the android logo re-appears, try and pushing either the volume up or volume down button.
    Next, check and see if it now displays the various command options on the screen.
    Otherwise, when the android logo reappears, you can try press one of the following 'home button' or 'back button' or 'opened tabs button' and see if the reset menu/command options become displayed.
    Oct 03, 2017 | PANDIGITAL Novel white
    Trio stealth g2 just shows start up screen won't boot up
    my table resets up on ever boot , you have to renter all the info every time you boot it up, Trio G2 10in
    Aug 11, 2013 | Mach Speed Trio Stealth G2 Tablet -...
    Android tablet stays in Android screen
    Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
    2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
    Feb 27, 2013 | Craig CMP741d Tablet
    Cruz T103 android upgrade problems!
    You should try doing the whole process all over again. If it still won't turn on then it's time to flash the firmware into the tablet using your computer.
    Mar 31, 2017 | Micro Innovations Velocity T103 Tablet PC
    AKASO KingPad 7 Google Android 4.1 Dual Core IPS Tablet MID PC, Rockchips RK3066 Dual Core Cortex A9 CPU up to 1.6GHz, 1Gb RAM, 8Gb HDD, HD IPS LED Multi-Touch Screen 1024x600, Front Camera Rear Camera, Google Play Pre-Installed, HDMI 1080P Output, Skype V Logo
    240 people viewed this question
    Top AKASO Tablets & eReaders Experts
    Marvin
    Marvin
    Are you an AKASO Tablet and eReader Expert? Answer questions, earn points and help others
