Hello Bob;
My name is Peter. I am a retired field service appliance technician.
I assume you are not referring to the lint filter on the top of your dryer.
Behind your dryer is a elongated hot air distribution manifold. Looking from the back of your dryer it is on the left. The manifold is fixed to the back of the dryer with screws. Unscrew the screws and remove the cover.
In the bottom of this manifold is where air flow blockage occurs. Clean this inlet out.
At this location you will not be exposed to any electrical or moving parts.
Cleaning this outlet will enhance the dryer air flow and dryer performance.
SOURCE: kenmore 110.72512101 gas dryer
Are you getting little or no lint on the lint screen? Are the clothes coming out nearly as wet as they went in, but feel warm? If so, you probably have a blockage somewhere in the vent/duct. Don't just check the back of the dryer, but also check the duct thru the wall and the point where it exits the house (exterior wall or roof). Many times birds will nest in the exterior vents or if they have a screen to keep the birds out it may become clogged with lint. If you have a window nearby try drying a load with the vent hose disconnected from the wall and hang it out the window (you COULD vent it into the house, but you may end up with lint everywhere and a lot of moisture in your house).
SOURCE: Dryer runs but does not get hot
It is your heating element,replacing it yourself will be a lot cheaper.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
SOURCE: Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
SOURCE: Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
