Boating Logo
w
william pucher Posted on Nov 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the shaft length of my 1998 mercury tracker outboard Serial number OG676641
25 hp 4 stroke
phillipelecu
Level 2:
Champion:
  • Expert 254 Answers
  • Posted on Nov 03, 2014
phillipelecu
Expert
Level 2:
Champion:
Answers
254
Questions
0
Helped
71280
Points
313
Measure from the cavitation plate (the one above the prop) to the u bend where the motor hangs on the transom. They are usually considered 15", 20", 25".
Testimonial: "I appreciate the answer, however i do not own the motor. I have the model, and serial number, and would like to make an offer to purchase if it it has a short shaft."
  • phillipelecu
    phillipelecu Nov 03, 2014
    Not enough info. Looking at 1998 models, the serial does not come up. There are also multiple models in the 25 HP line for that year. Sorry. If you cannot see and hear the motor run, I would steer clear.
5 Related Answers
Anonymous
  • 77 Answers
  • Posted on Jul 02, 2009
SOURCE: mercury outboard 60 motor turning over but not firing up.
get some starting fluid and spray a liberal amount into the air intake, then try to turn over. if it will not turn over with starting fluid you have a problem either with your ignition system, example: plugs, coils, wires, ect. If it does fire and then die out with a shot of starting fluid then you have a carb problem. If the boat has been sitting anything over a month thats where I'm betting the problem is. Post back after you find out if its a fuel, or fire issue and we'll start the repair process.
Anonymous
  • 53 Answers
  • Posted on Nov 04, 2009
SOURCE: I have a 2009 40hp 4 stroke outboard. It sounds
not enough info. what Manufacturers and model? is it out of warranty? here are some troubleshooting tools and procedures since labor rates at your local dealer could be up to $100.00 per hour. before you start I have two Goals for you. (1) If you learn everything you can about your engine you will become more confortable and enjoy it more. (2)confirm that your engine is ok now. is the noise your hearing piston related, or is it ignition missfire. the compression check and the ignition output test will help answer that. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the Manufacturer I'm giving you a average numbers. Look at your Clymer manual for specifics. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark output. use a spark gap tester. all cylinders should jump a half inch gap. If all these test prove that the basic operation of the engine are within specification, then we can turn to fuel delivery. unfortunately you didn't give the Manufacturer so I can't give you the troubleshoot procedures for the fuel delivery system. you will need to refer to the manuel. please get Clymer manuel you will apreciate it
Anonymous
  • 53 Answers
  • Posted on Nov 18, 2009
SOURCE: I have a 2002 ox66 Yamaha 2 stroke 250 hp std
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Testimonial: "Thanks i will try."
Anonymous
  • Posted on Mar 09, 2010
SOURCE: what oil gas ratio for 4 hp mercury motor serial number 3770379
1974 75 oil ratio 50.1
tsauvageau
Tony Sauvageau
  • 56 Answers
  • Posted on Apr 09, 2013
SOURCE: mariner 4 hp 2 stroke outboard starts but will not run
Could be the drive shaft, or maybe your propeller.
http://forums.iboats.com/mercury-mariner-outboards-25/
What is the weight and length of a 2005 Mercury 2 stroke long shaft boat motor?
Depends on the HP of the motor. The long shaft will only ad a few lbs. See this link for motor specs on weights.
https://www.nadaguides.com/Boats/2005/mercury/outboard-motors
1helpful
Is a Mercury 20 hp (2 cylinder) outboard a 2 or 4 stroke engine
Check the actual model and serial number with Mercury. If newer it’s possibly a four stroke. If it’s an older motor it’s more likely to be a two stroke.
I have a mercury outboard with serial # 5636683. Can you give me the shaft size of the motor?
Hey Robert,
What motor do you have?.. Size, year, two stroke/four stroke..etc.. and what shaft are you talking about?
Mercury Outboard Manuals by Seloc 1965 2014
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
