Tablets & eReaders Logo
Lisa Swain Posted on Nov 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How long does it take to do s factory reset on a zeki tbdg874b? Mine froze up and i almost didnt get turned off.
Sam Sebastian Farkas DaWolf
Level 2:
Novelist:
  • Expert 174 Answers
  • Posted on Nov 02, 2014
Expert
Level 2:
Novelist:
Answers
174
Questions
Helped
70225
Points
428
Depends on whats running in the background etc but normally not long...so just incase you haven't fixed problem I recomend you read and maybe give it a try.
Keep in mind this will erase personal data stored on device BUT if not concerned then freely go for it. Zeki Tablet stuck on loading screen Android Forums
Best of Luck
Mikey
Level 3:
Top Expert:
  • Tablets & eR... Master 6,904 Answers
 Mikey
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623345
Points
26106
Factory resets vary but typically anything upto 5 minutes!
How do i reset my zeki tablet when the factory reset wont work
on Zeki Tablet you had to hold both the "Reset" button and the "volume up" button at the same time for about 15-20 seconds it than boots into Safe Mode which you can select a full factory reset. NOT VOLUME DOWN.
If this fails, 1 888 999 4215 is Zeki support. If in warranty, tell them of failure of factory reset. They may request it be sent to them.
I have reset my zeki tablet I did this again earlier today rest it then gets froze and yet agin I turn it off wait a few go bak have to reset it again I mean the works
You will need to backup your stuff and then do a factory reset.
Then download the latests updates before putting your stuff back on.
I bought a charger from walmart for my zeki tbdg874b and it has a positive or negative switch which one do i put it on?
Look on the back where the jack is for the charger. Observe the symbol of the charger plug. There will be a + or - on the center pin. Match the charger with the tablet BEFORE you connect it.
I turn on my zeki 7' dual core tablet and it turns on but stays on the zeki logo screen and wont load..
Go to this site for the instructions on how to do a hard reset on your tablet.
http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
My 7" zeki tblet model TBDG773B comes on and shows android and nothing else will.
You can try a factory restore, but if that doesn't work you will need to buy a new tablet. These cheap tablets are throw-aways unfortunately. Note that a factory restore will erase any files you have on the device.
Factory Restore on Android devices:
- Turn off the device
- Hold Volume Down and also press the Power button until a menu comes up
- Use the Volume Up and Down buttons to select Factory Reset (or Restore)
- Press Power to select
1helpful
My zeki stuck on the zeki logo
You need to do a factory reset!
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user data"
  8. Press the power button to select
Your tablet will take several minutes to reboot to a factory default setting.
I have a zeki tablet that won't load, wondering if anybody here can help me?
I'm assuming it is the Zeki 8" TBDG874B. What I would do to get it of the flashy Android logo is hold down the volume button on the minus (-) side and get a small pin or needle to tap the reset. While holding the volume it will reset, then tap the power button still holding volume it will bring up a list. Do a factory reset (you lose all data but that's what I would to do to be on the safe side).
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
