Jabra BT350 Bluetooth Headset Headset Logo
Tecordea Copeland Posted on Nov 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I pair my ;Jabra A335W Blue Tooth,to my;Windows 8.1 ASUS 2014 Lap-Top?
I have an;Jabra Blue Tooth,and I don't know how to pair it to my ;Windows 8.1 ASUS Lap-Top?
Brett Duxbury
Level 3:
  • Jabra Master 4,352 Answers
  • Posted on Nov 02, 2014
Brett Duxbury
Jabra Master
Level 3:
Answers
4352
Questions
0
Helped
1119156
Points
13423
Http://www.youtube.com/watch?v=C5koqNKSjB8
I could try and explain it but this video link below explains it reaaly well
http://www.youtube.com/watch?v=qUtvbRSx00A
laptop has to have bluetooth ability if it doesn't get an usb bluetooth adapter
5 Related Answers
A
Anonymous
  • Posted on Feb 05, 2008
SOURCE: Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Anonymous
  • Posted on Aug 23, 2008
SOURCE: Cannot pair a7010 with Plantronics Voyager 520
The actual problem was Plantronics, I was not turning on pairing mode. I was confused with quick pair which starts not immediately after turning on, but you need to hold the button longer until led will start blinking blue and red.
Anonymous
  • 4 Answers
  • Posted on Sep 10, 2009
SOURCE: i cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
TO Lady
  • 638 Answers
  • Posted on Jan 05, 2010
SOURCE: Jabra OTE3 won't pair with Verzon LG phone. How do
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
vanherringto
J. Van
  • 1738 Answers
  • Posted on Feb 07, 2010
SOURCE: i have paired my jabra vbt 2050 to my ps3 and
Please review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks......
1helpful
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
HTC evo will not pair w my jabra stone, says incorrect pass code, how do I re enter the pass code?
By putting the blue tooth device in discovery mode it will reset it then your will have to enter the manufactures factory pin pairing code,Most blue tooth manufactures use a 4 digit pin pairing code,they are as follows0000,1234,1111,or 9999 this should be the code you are looking for i hope this helps
2helpful
My lg prime will not pair with my jabra bt3030 bluetooth headset
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
My wife lost her iphone and i cant get her new iphone to pair with her old jabra blue tooth
Hello Chris,
Did you try going into "discoverable" mode in the headset?
Please follow these steps and this should help you pair it with the iPhone.
1. Go to Settings > General > Bluetooth 4. Ensure Bluetooth is turned On 5. Ensure the headset is turned Off 6. Press and hold the Answer button until you have a solid blue LED 7. Touch the headset in the list (on iPhone) 8. The passkey is 0000 (4 zeros) 9. Enter the PIN 10. Tap Done
If that's not the problem, then let me know. I'll be glad to help you out.
Please rate this solution if it helps you.
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
1helpful
2answers
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
1helpful
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 • Cell Phones
1helpful
Unable to make or receive calls using Bluetooth.
try to remove the Jabra Blue tooth that you have under th list of your paired devices. try to turn off the phone and blue tooth then pair it again.
Jun 25, 2009 • Cell Phones
I have a Jabra set, but my Motorola Krazer can not find it
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
