When I insert The Nikon EN-EL 10 OR Fuji NP-45 battery in the charger, they pop right back out. I ordered one, didn' work so returned it and ordered another. Same problem. I checked to be sure I had contacts lined up correctly. Chargers function if I hold batteries in place. Charger lists these two batteries as compatable.
I have a feeling that the batteries might be the issue.
They might have dead cells or if they got to hot or cold the battery case can swell a little.
That will cause the issues you are experiencing.
Have A Good Day
Testimonial: "The answer referred to ryobi batteries. I have no ryobi tools, batteries, or chRGERS."
SOURCE: Camera won't charge
It could be the batteries but my bet is the charger is bad. If you have access to another charger try using it instead. I just had a similar problem a month ago where my charger pretended to work but never really put much of a charge on the batteries.
SOURCE: Battery charger(BC-11L)
Battery charger will not hold its charge. the red light keeps blinking
SOURCE: Battery charger light flash
Its pretty simple to fix. The lithium battery has just depolarized. Just buy a 9V battery.... put them end to end... the 9V and the lithium and touch the metal parts of them. hold for 20 seconds... if it doesn't work, lick the 9V to conduct the electricity better.. hold for 20 seconds and put directly on the charger... I just did this, and it is charging as we speak! good luck!
SOURCE: Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
SOURCE: Trying to charge up my battery for EXILIM EX-Z75
new battery flashing red light means bad battery
