Dell 3010cn Laser Printer Logo
A
Anna Nymous Posted on Nov 01, 2014
Dell 3010cn prints only blank pages
We bought this printer second hand only to find it prints exclusively blank pages, even the test page. Some residual specks of dark color ("toner dust") is visible on these pages. The paper is warm after "printing". We have installed new toner cartriges, though not original Dell toner but some no-name compatible. This problem persists using both Linux and Windows drivers, and both USB and Network connection. Any thoughts on what might be wrong? Thanks a lot for your help!
Jose Castillo
Level 1:
Habit-Forming:
New Friend:
  • Contributor 15 Answers
  • Posted on Nov 01, 2014
Jose Castillo
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
15
Questions
11
Helped
12156
Points
49
Dear Anna: Like your problem is related with the laser unit (ROS ASS), I mean, the printer do not print to the paper the image that have or could have in the drum.
We need to test if this is the problem. To do this, please, with much care: turn on the printer, wait it do it the initial test (5 to 15 seconds more or less), verify have paper in the correct position and the size too in the tray. Print a "config page", but not from "Windows, instead of the same printer. For do this: press Menu, with the vertical or horizontal litle sparrow , chose "print information", then choose "config page" and press the central key to execute it.(See page 32 of this document: http://configpages.blogspot.com/2012/01/dell-3000cn.html)
If you want, look this links beside: ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-3010cn_User%27s%20Guide_en-us.pdf.
And: http://configpages.blogspot.com/2012/01/dell-3000cn.html
If the config.page was printed well, the printer is not the problem. Try to uninstall the drivers of this printer and then reinstall the right and updated drives from the DELL web link and test again from Windows now.
But if the config. page was printed "in blanking", we have other problem, like the lasser unit.
If you now how to get out a page was have a paper jam in this printer, do it the following actions, if not, do not follow please, because could cause a major problem.
I will give you the actions to take it if you do not resolve the problem with the indicated. Please give your information that what happened.
Testimonial: "Dear Jose, thank you very much for your attention! Unfortunately, the config page comes out blank, too. (I said "test page" incorrectly.) There is no paper jam, as the pages move through the printer correctly, except that the toner does not stick to them. Also, before installing the new toner I checked the interior. Sorry that this hasn't solved the problem yet, but maybe you can help me still? Cheers!"
  • Jose Castillo
    Jose Castillo Nov 03, 2014
    Dear Anna! Very good for your testimonial. Never use anything but OEM drums and toner in this printer. Is a litle hard to say that problem is the lasser scanner.The "config.page" is not the "test page", the last is from Windows, the first is from the "bios" of the printer. Get out the imaging drum, I put an image of them. Check it very well. Have a movile parte
  • Jose Castillo
    The imaging drum have a cilynder with a photosensitivity surface, check in there is any text write on them, if it is totally clean, this mean the laser unit do not write on the drum, but could be the lasser ray do not come to the drum surface because there is an object that does block the ray. Check this well. Check cables and connectors too on the belt drive, i put another image of the belt drive. Check all very well, and replay the results.
5 Related Answers
Anonymous
  • 191 Answers
  • Posted on Dec 20, 2007
SOURCE: diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
  1. Press the Menu button.
  2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
  3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
  4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
  6. Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
  1. Power off the printer.
  2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
  3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
To print all four 20% toner test prints, perform the following step:
  4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. The test print will print.
  6. Press the Cancel button.
  7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  8. Press the return%20arrow%203100cn.jpg button. The test print will print.
  9. Press the Cancel button.
  10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  11. Press the return%20arrow%203100cn.jpg button. The test print will print.
  12. Press the Cancel button.
  13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  14. Press the return%20arrow%203100cn.jpg button. The test print will print.
  15. Press the Cancel button.
  16. Power off the printer and power back on.
Reseat the drum cartridge, perform the following steps:
  2. Unplug the power cable.
  3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
    Figure 1 - Open Front and Top Covers
  4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2 - Raise Lever to Release Drum Cartridge
  5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3 - Remove Drum Cartridge
  6. Insert the drum cartridge.
  7. Close the top and front covers.
  8. Plug in the power cable.
  9. Power on the printer.
Anonymous
  • 12 Answers
  • Posted on Jan 31, 2008
SOURCE: A10A940 Dell Printer
Our black ink quit printing, cleaning did not help. I finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Anonymous
  • 55 Answers
  • Posted on Mar 02, 2009
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Anonymous
  • 6 Answers
  • Posted on Dec 01, 2009
SOURCE: Dell 3010cn white stripe
on the 3010cn open from cover, follow instruction for pulling up the lever and sliding the bar out of the side repeat the slide motion 15 to 20 time. this action cleans the printing plate and will elimiate the strip. the strip is caused be toner leaking on to the plate it the strip returns repeat the steps.
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
My printer prints blank pages
do you have to copies of the same printer in control panels printer menu? dell printer
My Dell 3010cn has does not print the far right hand part of the page any longer. I have replaced toner, drum and looked for blockage. What could be the problem?
It is most likely be due to dust/ toner dust accumulation at the laser reflecting mirrors inside the copier, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck!
CreativeTECH
My DELL 3010CN is printing a thick black line on the right hand margin on all pages printed.
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
My printer simply prints blank pages. When i run the test page this prints fine. all documents are held in a cue but never print. I have bought brnad new cartridges from dell as the last 1ns i had were...
go to page 56 of the manual(http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdfif you don't have it) the issue is about half way down the page. good luck!
2answers
Dell a940 all in one printer
hmm..ok..if the test page is good, then it's in the drivers. get new ones, remove old ones first, re install try again.
My Dell 962 printer only prints blank pages.
The ink is dry.
Try repeatly going through a cleaning cycle.
If not, remove all ink cartridges and pour some 100% Alcohol where the cartridge is and leave it there for 1 hour.
Afterwards, go through a few more cleaning cycle.
Make sure you have spare ink.
3answers
1helpful
2answers
Not printing extreme right side of page
It is either your drum or open front cover see blue handle @ right hand side pull it out look at rignt hand side of printer and a door has opened (only small) pull the blue lever out and move the pad back andforwards a few times this cleans the glass.
It worked for me but I have to do it fairly often but it samve buying a new drum etc
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
