Everything on the xr2 remote works except the main menu and guide. A setup screen displays instead
Try by set it with an other code said to your TV brand. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Good suggestion, but the remote was synched just fine with the first number we tried. Found the problem. We just upgraded from analog service to HD so comcast sent us a new cable box to install. Problem is, I looked at the bill and they should have sent a new set-top box. Instead they sent a uDTA box. The uDTA boxes apparently don't access the guide and on Demand menus. Cable guy is coming tomorrow to bring us the right box.
How can I change analog channels on with xr2 remote
I have LG TV when I switch from cable box to to tv can not change channels with xr2 remote why everything else works is there a special code I have to enter.
