It leaks and drains onto the counter when I try to brew coffee
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
SOURCE: Cuisinart DCC-1200 BW Model leaks
Order 1 foot of 5236K73 "High-Temperature Silicone Rubber Tubing" from McMaster-Carr. Put the old check valve in the new tubing in the same location and direction as originally installed.
SOURCE: my 10 cup Bunn coffee maker leaks from the top
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
SOURCE: The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
