The glass covering has shattered and I removed it.
SOURCE: No Power
Brown, I need the first 3 letters of that model number. This model number is not complete, it comes up as a television...Catriver..post back.
SOURCE: broken glass cook top
You probably need to replace it. They are though fairly expensive. A little under $200 to be exact. http://www.partstore.com/ModelSearch.aspx?MfgName=Maytag&BrandName=JennAir&CloselyRelatedModels=true&ModelNumber=JED8430&x=41&y=30
SOURCE: Scratch Removal
I remeved the scratches on mine with a 600 gritt sand paper, but you have to do it wet, wet the sand paper and keep it wet, it takes a lot of sanding but it workd and do not show marks
Hope this help
Eddie Rentas
Tupper Lake
SOURCE: I cracked my Schott Ceran Cooktop glass
I located a company that supplies a new top but only to find that the tops are 400.00 anyway. I ended up purchasing a new stove to solve the problem.
SOURCE: Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
