Try to push or pull lens while turning camera on and off
Hi
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.
Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
